    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 52.1k Views 14 Watching
    • T
      trividar
      No one an idea?
      • BangeeB
        Bangee Module Developer
        I am using a PIR sensor.
        So i can’t reproduce it.
          PaulB
          Dear guys,
          Ive tried to run this skript,nevertheless it’s showing me ‘undefined’ when I am running it in MM-Mode.
          Ive already checked the Pin setup and it should be right. Furthermore Ive checked your advises in the posts above me.
          Do you have an idea how to fix this error or even how to get an idea where the error is? :D
          Kind regards :)
          • BangeeB
            can you post a pic of your wiring?
            when you run the command sudo ./dht_var direct in your console, what happens?
              schmo90
              hy
              i have also the problem that the sensor shows only undefined.
              if i run your dht_var it shows nothing…
              sudo ./dht_var 2 5 returns after 5 seconds without any message…
              found out that it is only not working if i have enabled the PIR-Sensor Modul…
              • F
                fabrang @MxBln
                @MxBln I have the same question. It works, but it shows me way to high temperatures and humidity. How did you do it with a DTC11 ?
                  beck0r
                  same here, shows loading for a very long time and ‘undefined’ afterwards
                  the sensor is working, see here:
                  0_1496151901454_upload-79b4ac08-535a-4fe6-848e-99f80fe7650d
                  any idea?
                    Dracarys
                    Are there any news for this module? I have the exact same thing with this module and the DHT22. Sometimes it shows everything correct and then it shows either “undefined”, nothing or ~ “-3200°C”. So it changes almost everytime it refreshes.
                    I also use the PIR module like Bangee but it doesnt matter if i have this modules activeted or not …the problem still is there.
                    sudo ./dht_var 22 5
                    doesn’t do anything. It just returns with no massage like it does by schmo90.
                    Hope somebody can help us :)
                      ryck Module Developer
                      Hi. I have the same issue, no response in the module or in the command line…
                      I am also using a PIR sensor, maybe it’s related?
                      J 1 Reply Last reply
                        Johans @ryck
                        @ Bangee
                        installed modules as described in read.me file but I get no reading of temp or hum.
                        sensor is working, tested with AdaFruit example
                        sudo ./AdafruitDHT.py 2302 27 (Data connected to gpio 27)
                        I get a perfect temp & hum reading, so i’m shure sensor is working.
                        i’m using an RPI3 - according to wiring pin, wpi 2 = gpio27 = physical pin 13.
                        I think wiring is OK.
                        only clock and this module installed.
                          PaulB
                          Hey guys :) Hope you are all good.
                          Finally I have the time to work on this module again :)
                          I had the same errors like you before and unsuprisingly did not found a solution for it.
                          Is someone in this thread still active?
                            Johans @PaulB
                            @PaulB - glad you have found some time to work on it.
                            Yes I still have the problem with reading the data in the MM.
                            Hope you can find the cause. I would like to help you, but i’m not a programmer.
                            The only thing I could help on is perhaps some beta testing.
                            Cheers.
                            Johan
                            • DocVooDooD
                              DocVooDoo
                              Hey, i have the same problem.
                              With “./Adafruit_Python_DHT/examples/AdafruitDHT.py 22 27” comes the Temperatur “Temp=20.1* Humidity=29.3%”
                              The DHT22 is Pinned on PIN 13 (27) (WiringPi 2). On the Mirror is the Temperatur and the Humidity undefined.
                              Whats the Problem? I found nothing…
                              R 1 Reply Last reply
                                ryck Module Developer @DocVooDoo
                                @DocVooDoo Then I don’t know, maybe there is something wrong with the module…
                                Have you tried mine? https://github.com/ryck/MMM-DHT-Sensor
                                DocVooDooD 1 Reply Last reply
                                • DocVooDooD
                                  DocVooDoo @ryck
                                  @ryck Hi. yes, a minute ago. He says “no data returned”.
                                    @DocVooDoo sometimes the raspberry pi needs some time to pick up the values… try to increase the update time (ie, 30 seconds) and wait for it to update a couple of times…
                                    • DocVooDooD
                                      DocVooDoo @ryck
                                      @ryck nothing has changed. i have “node serveronly” running, and the log says “Error: failed to read sensor at Error (native)”
                                      but the sensor works… look
                                        @DocVooDoo Weird… did you follow all the instructions? ie, install bcm2835, npm install, etc?
                                        • DocVooDooD
                                          DocVooDoo @ryck
                                          @ryck Yes of course.
                                            @DocVooDoo No idea then… Can you paste here the error you get?
                                            • 2 / 3
