    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 52.1k Views 14 Watching
    • T
      trividar
      I have test it with two dht22. One was mine and one I received from @Bangee who was so kind to test it before sending it and it was working at his home, but when I tried it at my home it wasn’t working. So I have no Idea what can be the failure.
      • T
        trividar
        Hi ,
        so I just figure it out, that the motiondetector by alexyak blocking the DHT22 script. If I disable this module my DHT 22 works perfect. Somebody knows what make this problem?
        • BangeeB
          Bangee Module Developer
          that’s very strange!?!
          Is this module working with a PIR Sensor or a Webcam?
          Im using Paviro’s PIR Sensor to turn on an off my monitor.
          • T
            trividar
            With picamera. I installed MM on my other pi (completely new installation) and i got the same problem after i installed the motion detector. So I disabled on my MM the motion detector and it works fine on both pi’s. It’s very strange ;o(
            • T
              trividar
              No one an idea?
              • BangeeB
                I am using a PIR sensor.
                So i can’t reproduce it.
                  PaulB
                  Dear guys,
                  Ive tried to run this skript,nevertheless it’s showing me ‘undefined’ when I am running it in MM-Mode.
                  Ive already checked the Pin setup and it should be right. Furthermore Ive checked your advises in the posts above me.
                  Do you have an idea how to fix this error or even how to get an idea where the error is? :D
                  Kind regards :)
                  • BangeeB
                    can you post a pic of your wiring?
                    when you run the command sudo ./dht_var direct in your console, what happens?
                      schmo90
                      hy
                      i have also the problem that the sensor shows only undefined.
                      if i run your dht_var it shows nothing…
                      sudo ./dht_var 2 5 returns after 5 seconds without any message…
                      found out that it is only not working if i have enabled the PIR-Sensor Modul…
                      • F
                        fabrang @MxBln
                        @MxBln I have the same question. It works, but it shows me way to high temperatures and humidity. How did you do it with a DTC11 ?
                          beck0r
                          same here, shows loading for a very long time and ‘undefined’ afterwards
                          the sensor is working, see here:
                          0_1496151901454_upload-79b4ac08-535a-4fe6-848e-99f80fe7650d
                          any idea?
                            Dracarys
                            Are there any news for this module? I have the exact same thing with this module and the DHT22. Sometimes it shows everything correct and then it shows either “undefined”, nothing or ~ “-3200°C”. So it changes almost everytime it refreshes.
                            I also use the PIR module like Bangee but it doesnt matter if i have this modules activeted or not …the problem still is there.
                            sudo ./dht_var 22 5
                            doesn’t do anything. It just returns with no massage like it does by schmo90.
                            Hope somebody can help us :)
                              ryck Module Developer
                              Hi. I have the same issue, no response in the module or in the command line…
                              I am also using a PIR sensor, maybe it’s related?
                              J 1 Reply Last reply
                                Johans @ryck
                                @ Bangee
                                installed modules as described in read.me file but I get no reading of temp or hum.
                                sensor is working, tested with AdaFruit example
                                sudo ./AdafruitDHT.py 2302 27 (Data connected to gpio 27)
                                I get a perfect temp & hum reading, so i’m shure sensor is working.
                                i’m using an RPI3 - according to wiring pin, wpi 2 = gpio27 = physical pin 13.
                                I think wiring is OK.
                                only clock and this module installed.
                                  PaulB
                                  Hey guys :) Hope you are all good.
                                  Finally I have the time to work on this module again :)
                                  I had the same errors like you before and unsuprisingly did not found a solution for it.
                                  Is someone in this thread still active?
                                    Johans @PaulB
                                    @PaulB - glad you have found some time to work on it.
                                    Yes I still have the problem with reading the data in the MM.
                                    Hope you can find the cause. I would like to help you, but i’m not a programmer.
                                    The only thing I could help on is perhaps some beta testing.
                                    Cheers.
                                    Johan
                                    • DocVooDooD
                                      DocVooDoo
                                      Hey, i have the same problem.
                                      With “./Adafruit_Python_DHT/examples/AdafruitDHT.py 22 27” comes the Temperatur “Temp=20.1* Humidity=29.3%”
                                      The DHT22 is Pinned on PIN 13 (27) (WiringPi 2). On the Mirror is the Temperatur and the Humidity undefined.
                                      Whats the Problem? I found nothing…
                                      R 1 Reply Last reply
                                        ryck Module Developer @DocVooDoo
                                        @DocVooDoo Then I don’t know, maybe there is something wrong with the module…
                                        Have you tried mine? https://github.com/ryck/MMM-DHT-Sensor
                                        DocVooDooD 1 Reply Last reply
                                        • DocVooDooD
                                          DocVooDoo @ryck
                                          @ryck Hi. yes, a minute ago. He says “no data returned”.
                                            @DocVooDoo sometimes the raspberry pi needs some time to pick up the values… try to increase the update time (ie, 30 seconds) and wait for it to update a couple of times…
                                            • 2 / 3
