    MMM-DHT22 Humidity and Temperature Module
    47 Posts 14 Posters 51.6k Views 14 Watching
      beck0r
      same here, shows loading for a very long time and ‘undefined’ afterwards
      the sensor is working, see here:
      0_1496151901454_upload-79b4ac08-535a-4fe6-848e-99f80fe7650d
      any idea?
        Dracarys
        Are there any news for this module? I have the exact same thing with this module and the DHT22. Sometimes it shows everything correct and then it shows either “undefined”, nothing or ~ “-3200°C”. So it changes almost everytime it refreshes.
        I also use the PIR module like Bangee but it doesnt matter if i have this modules activeted or not …the problem still is there.
        sudo ./dht_var 22 5
        doesn’t do anything. It just returns with no massage like it does by schmo90.
        Hope somebody can help us :)
          ryck Module Developer
          Hi. I have the same issue, no response in the module or in the command line…
          I am also using a PIR sensor, maybe it’s related?
            Johans @ryck
            @ Bangee
            installed modules as described in read.me file but I get no reading of temp or hum.
            sensor is working, tested with AdaFruit example
            sudo ./AdafruitDHT.py 2302 27 (Data connected to gpio 27)
            I get a perfect temp & hum reading, so i’m shure sensor is working.
            i’m using an RPI3 - according to wiring pin, wpi 2 = gpio27 = physical pin 13.
            I think wiring is OK.
            only clock and this module installed.
              PaulB
              Hey guys :) Hope you are all good.
              Finally I have the time to work on this module again :)
              I had the same errors like you before and unsuprisingly did not found a solution for it.
              Is someone in this thread still active?
                Johans @PaulB
                @PaulB - glad you have found some time to work on it.
                Yes I still have the problem with reading the data in the MM.
                Hope you can find the cause. I would like to help you, but i’m not a programmer.
                The only thing I could help on is perhaps some beta testing.
                Cheers.
                Johan
                • DocVooDooD
                  DocVooDoo
                  Hey, i have the same problem.
                  With “./Adafruit_Python_DHT/examples/AdafruitDHT.py 22 27” comes the Temperatur “Temp=20.1* Humidity=29.3%”
                  The DHT22 is Pinned on PIN 13 (27) (WiringPi 2). On the Mirror is the Temperatur and the Humidity undefined.
                  Whats the Problem? I found nothing…
                    ryck Module Developer @DocVooDoo
                    @DocVooDoo Then I don’t know, maybe there is something wrong with the module…
                    Have you tried mine? https://github.com/ryck/MMM-DHT-Sensor
                    DocVooDooD 1 Reply Last reply Reply Quote 0
                    • DocVooDooD
                      DocVooDoo @ryck
                      @ryck Hi. yes, a minute ago. He says “no data returned”.
                        @DocVooDoo sometimes the raspberry pi needs some time to pick up the values… try to increase the update time (ie, 30 seconds) and wait for it to update a couple of times…
                        • DocVooDooD
                          DocVooDoo @ryck
                          @ryck nothing has changed. i have “node serveronly” running, and the log says “Error: failed to read sensor at Error (native)”
                          but the sensor works… look
                            @DocVooDoo Weird… did you follow all the instructions? ie, install bcm2835, npm install, etc?
                            • DocVooDooD
                              DocVooDoo @ryck
                              @ryck Yes of course.
                                @DocVooDoo No idea then… Can you paste here the error you get?
                                • DocVooDooD
                                  DocVooDoo @ryck
                                  @ryck only this Bild Text
                                  then nothing on the log in node serveronly screen
                                    @DocVooDoo well, no idea then… Have you tried to run the normal version (instead of the serveronly)?
                                    DocVooDooD 2 Replies Last reply Reply Quote 0
                                    • DocVooDooD
                                      DocVooDoo @ryck
                                      @ryck yes, the same problem…
                                      • DocVooDooD
                                        DocVooDoo @ryck
                                        @ryck is it possible that the module root rights needs but does not get?
                                        with another module comes the same error. root privileges are needed there
                                          @DocVooDoo I guess that depends on how you installed magicmirror… did you use sudo?
                                          • DocVooDooD
                                            DocVooDoo @ryck
                                            @ryck no, without sudo. only with the command
                                            bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                                            • 2 / 3
