    MMM-voice
    voice control
    329 Posts 55 Posters 973.8k Views 50 Watching
    • daenickD Offline
      daenick @strawberry 3.141
      Yes, that was the first thind I do, but doesn´t works…
      Mysteriously after of the installation of MMM-mail could continue
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @daenick
        @daenick so it is installed now?
        • daenickD Offline
          daenick
          No, now I get this:
          alt text
            @daenick looks like you executed the installer with sudo
            daenickD 1 Reply Last reply Reply Quote 0
            • daenickD Offline
              @strawberry-3.141 can try again without restart everything?
              By the way, you are so friendly. Thanks!
                @daenick remove the node_modules folder in MagicMirror/modules/MMM-voice first and go into /root/pocketsphinx and execute sudo make uninstall same in /root/sphinxbase then rerun the installer
                daenickD 2 Replies Last reply Reply Quote 0
                • daenickD Offline
                  @strawberry-3.141 I ran the bash without the sudo. Finish ok
                  • daenickD Offline
                    @strawberry-3.141 Hello Again,
                    Finnaly I got the MMM-voice installed, but how can I set the micro as default? Sometimes the micro can “hear me” but mostly of time no
                    There´s some kind of special configuration with the micro?
                    Thanks!
                      Advokaten
                      @strawberry-3-141
                      I get this error (or is it?) when starting MagicMirror.
                      MMM-voice: Starting pocketsphinx.
                      (node:1844) DeprecationWarning: Calling an asynchronous function without callback is deprecated.
                      The microphone icon appears and after it it states “ERROR”, within MagicMirror.
                      Thanks!
                        @daenick can you give more details about the issue? the only thing that is configurable is the mic the module should use like microphone: 0 or microphone: 1 …
                        @Advokaten what is inside the error.log, if you only can see numbers in there please enable debug: true in the config and share the debug.log
                        A daenickD 2 Replies Last reply Reply Quote 0
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 32
                        • 33
                        • 19 / 33
