    MMM-TrafficCal - Dynamically display commutes based on calendar entries
    13 Posts 6 Posters 11.5k Views 7 Watching
    • RedNaxR
      RedNax Module Developer
      [card:RedNax67/MMM-TrafficCal]
      C B 2 Replies Last reply
      Reply Quote 1
      • C
        chewitt86 @RedNax
        @RedNax This is potentially a very cool module, I’m still working on incorporating it into my mirror (I’m not a coder so takes me a while) but I did have a question as to whether or not I could change the module to have a fixed destination rather than to look up from a calendar?
        RedNaxR 1 Reply Last reply
        • RedNaxR
          RedNax Module Developer @chewitt86
          @chewitt86 There already is a static version of this (in fact, i hijacked it to make mine :) ) https://github.com/SamLewis0602/MMM-Traffic
          C 1 Reply Last reply
          Reply Quote 1
          • G
            gismo2006
            Hi, some days ago I try to use your module. I installed everything like you write at your readme file. I create a new calender. But It didn’t work. After some try, I read that it use a new function in the calender module. So I try to change to the develop tree. But after that my magic mirror didn’t start again. So I copy a previous version I have saved and the mirror started normally.
            Greets gismo
            • C
              chewitt86 @RedNax
              @RedNax Brilliant! thanks very much!
                A Former User
                A fantastic enhancement on the origional by the looks of it, thanks for taking the time RedNax.
                Question, all installed and configured.
                Apart from https://www.npmjs.com/package/request (npm install request)
                Any recommended method for installation on a mac?
                  shashank @Guest
                  @wjdw87 hi, I installed this module, i cannot see any display on MM with regards to TrafficCalc, may i know the steps how to enter info on a gmail calander for MYTRIP and Destination
                  • B
                    Bobby @RedNax
                    @RedNax I have some problems with this module. How should be a correct calendar entry? I cannot see anything on the mirror. This ist the only thing in the log:
                    received TRAFFIC_COMMUTE
                    TRAFFIC URLS:
                    TRAFFIC URLS:
                    TRAFFIC URLS:
                    TRAFFIC URLS:
                    Bobby
                    • RedNaxR
                      RedNax Module Developer @Bobby
                      @Bobby
                      Hi Bobby,
                      Your config should be something like this:
                      		module: "MMM-TrafficCal",
                      		classes: "dimmed medium",
                      			api_key: "API KEY to the calendar holding your trip planning, could optionally be a seperate one",
                      			origin: "Damrak 1, Amsterdam", // Your default trip origin. Must be an unambiguous google resolvable adress
                      			tripkey: "MYTRIPS", // A keyword to identify a TrafficCal calendar entry
                      			chinangeColor: true,
                      			limitYellow: 25,
                      			limitRed: 50,
                      			traffic_model: "pessimistic",
                      			interval: 120000
                          An example of an entry:
                      0_1486889620335_upload-cccf478f-b636-4ff2-962e-f4491bda83f8
                      You’ll have to run a calendar module with the MYTRIPS calendar entries in it. You can optionally hide it using the remote control module.
                      		header: "Trips",
                      		fetchInterval: 60000,
                      			maximumNumberOfDays: 1,
                      					symbol: "calendar-check-o ",
                      					url: "https://calendar.google.com/calendar/ical/YOUR URL TO THE TRIPS CALENDAR",
                      			titleReplace: {
                      				"De verjaardag van ": "",
                      				"'s birthday": ""
                      Good luck!
                      B S 2 Replies Last reply
                      Reply Quote 1
                      • B
                        Bobby @RedNax
                        @RedNax Thx, for your answer. I have solved my problem, my destination has German “umlaute (ä, ü, ö)” in name. Thus the google request did not clear. This is not utf-8. An other question is, what does ist mean “ipv”?
                         mycommute.commute + ' ipv ' + mycommute.noTraffic
                        Thanks fpr your help
                        Bobby
                        • RedNaxR
                          @Bobby Whoops, thats a Dutch abbreveation of ‘instead of’… Should really make that a config item… :S
                          • RedNaxR
                            RedNax Module Developer @RedNax
                            @RedNax New version has these strings as config items…
                              shashank @RedNax
                              @RedNax hi, i created the Calendar and able to view the MYTRIP details but TrafficCalc is not working
                              how and where to get this ApiKey
                              api_key: “API KEY to the calendar holding your trip planning, could optionally be a seperate one”,
