    MMM-AssistantMk2
    421 Posts 61 Posters 720.0k Views 57 Watching
    • ? Offline
      [[global:former-user]] @citizendevpi
      @citizendevpi
      Oh, You don’t need to modify source itself. the everything you had to adjust for your environment should be done in config.js, not MMM-AssistantMk2.js. If you need more configuration options, tell me.
        Arkitct
        @Sean this is awesome module, thanks! I have been successful in getting it installed and working with Hotword - responds and provides answers including integrating with calendar, etc. (can make appointment).
        But when I attempt to proceed with the instructions for “Register your Mirror as Google Assistant related device.” I am not sure what input to provide in the deviceInstance.json file for the YOUR_MODEL_ID. I have tried various permutations of what I think it is, but no luck.
        The instructions indicate it comes from the Google Project Console. Is this the Google Cloud Platform? There is a Project Name and Project ID listed on the Cloud Platform; are one of these the YOUR_MODEL_ID?
        Thanks!
        ? 2 Replies Last reply Reply Quote 0
        • ? Offline
          [[global:former-user]] @Arkitct
          @arkitct
          You’ve already made deviceModelId when you mad your credentials.json on first installation. (https://github.com/eouia/MMM-AssistantMk2/blob/master/INSTALL.md#get-auth-and-credentials-to-make-profile)
          If you have forgotten your deviceModelId,
          Go to Google Action console homepage(https://console.actions.google.com) Then find your project and the menu - Device Registration
          Of course, there are other methods to get Model Id (If you have a plan to get deviceInstanceId also, you need to use CLI. - See https://developers.google.com/assistant/sdk/reference/device-registration/register-device-manual
          • ? Offline
            @arkitct
            But… many features are restricted in this SDK, So I think you don’t need to register Mirror to your Google Home network. Even though your mirror registered on your phone looks very nice, but that’s all. :D
              Jmh474
              Sorry this is my first post, are there any guides for helping me install the MMM-assistantMK2 I’m a total beginner With the raspberry pi any help would be much appreciated
              • Cr4z33C Offline
                Cr4z33 @Jmh474
                @jmh474 Follow the link in the first post that bring you to GitHub.
                Once there follow CAREFULLY the step-by-step installation & configuration.
                Only then if there’s still anything not clear or not working ask here. ;)
                  Jmh474 @Cr4z33
                  @cr4z33 OK thanks mate
                    reddyman @Guest
                    For second issue; Are you using other module to control to hide and show modules? Maybe it makes to show specific module by force. There is no way to prevent force revealing by other module.
                    https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#visibility-locking
                    No luck here, I ended up doing a fresh install with no other modules installed and it still happens. Can’t figure why it only applies to the default weather app, even if I move the position.
                    I can’t figure out why no one else has this issue. Oh well, I guess I can just not use the “hide all” command though. Thanks!
                    citizendevpiC 1 Reply Last reply Reply Quote 0
                    • citizendevpiC Offline
                      citizendevpi @reddyman
                      @reddyman my mirror also pops up the default weather after hide all , I got use to it
                      • ? Offline
                        @citizendevpi @reddyman
                        I’ll check it as soon as possible.
                        • W Offline
                          wearable9083 @Guest
                          @sean
                          Thank you always for your complete modules.
                          I have some questions about YouTube. The YouTube video screen is always full. Is there a way to reduce the size of a pop-up window?
                          And one more thing: can’t I stop or give another command while watching the video?
                          • ? Offline
                            [[global:former-user]] @wearable9083
                            @wearable9083
                            For Resizing Video Player; add this into your css/custom.css and adjust the values;
                            #ASSISTANT_YOUTUBE {
                              position:fixed;
                              top:20px;
                              left:20px;
                              width:400px;
                              height:300px;
                            And you can stop playing video by hotword waking with option pauseOnYoutube:false.
                            W 1 Reply Last reply Reply Quote 1
                            • W Offline
                              wearable9083 @Guest
                              @sean
                              Thank you very much for your kind answer.
                              But, ;(
                              Detects hotword during video playback and stops video, but then fails to perform any of the following commands…
                              • ? Offline
                                @wearable9083 If you failed, just try again. I think it might be caused by some lack of resource performance but that might not be the fatal problem. Or, Did you mean AssistantMk2 not working after youtube playing?
                                • W Offline
                                  wearable9083 @Guest
                                  @sean
                                  After assistant-mk2 has detected hotword, no voice command has been recognized. (during video playback)
                                  [Voice commands are well recognized when the video is played through without stop.]
                                  • ? Offline
                                    @wearable9083
                                    Only after closing video, you can order to assistant.
                                    If command be allowed during video playing, Assistant will be activated by sounds of video. So during playing, Assistant is disabled.
                                    • W Offline
                                      wearable9083 @Guest
                                      @sean
                                      Thank you so much. ♥♥
                                      I’ll make the most of the information you’ve given me. Thank you. :)
                                      Have a nice day!
                                      • C Offline
                                        costascontis
                                        @Sean at last got MMM-AssistantMk2 up and running with MMM-Hotword.I have only one little problem,when i ask something i lose the first word of the answer.It is like hdmi sound channel is down and needs 1 sec to wake so i cant hear the first word of the answer.I add to /boot/config.txt the line “force_hdmi_open=1” but didnt help.At my standalone raspberry google assistant installation i had the same problem and this line solved it,but not here…
                                        • ? Offline
                                          [[global:former-user]] @costascontis
                                          @costascontis
                                          Sorry, I have no idea about it. Maybe my module would close HDMI when it doesn’t be needed. (Standalone version could open HDMI continuously by force, because there is no need to close for other’s occupation)
                                          • C Offline
                                            costascontis @Guest
                                            @sean it is very annoying not to listen the first word or missing the half of it,do you have an idea to keep hdmi on all the time?
                                            edit: if i use the .asoundrc file of my other gassistant i have no delay but the voice is choppy.
                                            pcm.dsnooper {
                                                type dsnoop
                                                ipc_key 816357492
                                                ipc_key_add_uid 0
                                                ipc_perm 0666
                                                slave {
                                                    pcm "hw:1,0"
                                                    channels 1
                                            pcm.!default {
                                                    type asym
                                                    playback.pcm {
                                                            type plug
                                                            slave.pcm "hw:0,1"
                                                    capture.pcm {
                                                            type plug
                                                            slave.pcm "dsnooper"
                                            if i use the default .asoundrc the voice is clear but with a start delay
                                            pcm.!default {
                                            	type hw
                                            	card 0
                                            ctl.!default {
                                            	type hw
                                            	card 0
                                            with the first .asoundrc delayless file all other sounds at the Rpi are playback just fine ,only the MMM-AssistantMk2 voice is grainy and choppy… : (
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 21
                                            • 22
                                            • 11 / 22
