    MMM-AssistantMk2
    421 Posts 61 Posters 777.6k Views 57 Watching
    • B
      bachoo786 @Davido
      @Davido thank you
        A Former User
        UPDATED
        [2.1.4] - 2019.03.26
        • Added : Now you can use recipes. https://github.com/eouia/MMM-AssistantMk2/wiki/Usage#recipes
          recipe is an external js file containing definitions of command, transcriptionHook and action. Your configuration could be more shorter.
        recipes:["hide_and_show_all_modules.js", "reboot.js", "screen_onoff.js", "shutdown.js"],
        Feel free to request PR to share your recipes to others.
        • Changed : onIdle, onDetected features are disabled by default.
        • B
          bryan_1
          @Sean
          sorry for my bad English. I use the default recipes and set the language to German for all pattern (“spiegel reboot”, “monitor aus”, etc). Every thing works fine, only the “SHOWMODULES” doesn’t work. Although the hotword is correctly detected, but nothing happens. I set the pattern for SHOWMODULE to pattern: “alle module”,
          This is also the same case if I use the OnIdle and OnActivate:
          onIdle: {
          timer: 10006020,
          command: “HIDEMODULES”,
          onActivate: {
          timer: 0,
          command: “SHOWMODULES”,
          I can hide the modules, but after the hotword for SHOWMODULES being recognized the modules aren’t shown again. What do I wrong? Many thanks in advance.
            A Former User @bryan_1
            @bryan_1
            Can you show me the recipe(command and transcriptionHook or gAction) about SHOWMODULES?
            • B
              bryan_1 @Guest
              @Sean
              thank you sean for your quick response. Actually I use the default hide_and_show_all_modules.js and change the pattern to german:
              var recipe = {
              transcriptionHook: {
              “HIDE_ALL_MODULES”: {
              pattern: “alle verstecken”,
              “SHOW_ALL_MODULES”: {
              command: {
              “HIDEMODULES”: {
              moduleExec: {
              module:()=>{
              return []
              exec: (module, params, key) => {
              module.hide(1000, null, {lockString:“AMK2”})
              “SHOWMODULES”: {
              moduleExec: {
              module:[],
              module.show(1000, null, {lockString:“AMK2”})
              exports.recipe = recipe
                @bryan_1
                try this instead module.show(1000, null, {lockString:“AMK2”})
                module.show(1000, null, {lockString: "AMK2", force: true})
                B 2 Replies Last reply Reply Quote 0
                • B
                  bryan_1 @Guest
                  @Sean I’ll try it tonight (I’m still at work now :smiling_face_with_smiling_eyes: ) and let you know. Many thanks…you did really a great job :thumbs_up_light_skin_tone: :folded_hands:
                    sdetweil
                    related to this topic, I haven’t been able to understand what I need to do.
                    I am trying to coordinate between the voice module go to sleep/wake up, and my motion detection module MMM-SleepWake.
                    My displays will not turn off programmatically, so I have to hide/show modules
                    But you only show what was NOT already hidden at time of sleep.
                    Voice says sleep, motion says wake… but… I need to know what was already hidden, so I don’t wake them up (restore to same state)…
                    with MMM-voice we developed a notification process, where the voice module does the sleep, but informs my module who was already hidden… so IF motion wakes up, i don’t accidentally show modules I shouldn’t…
                    wake up voice command works ok, (changed screenOn to notify my module to wake)
                    go to sleep is missing…
                    this is the socketnotification code in MMM-voice.js after voice detects ‘go to sleep’, only if using the hide/show sleep approach
                    if (notification === 'STAND_BY_ACTION') {
                                if (payload.type === 'show') {
                                    if (payload.hardware === false) {
                                        MM.getModules().enumerate((module) => {
                                            if (this.previouslyHidden.includes(module.identifier)) {
                                                module.show(1000);
                                        this.previouslyHidden = [];
                                    this.sendNotification('STAND_BY', { status: false });
                                } else if (payload.type === 'hide') {
                                            if (module.hidden === true) {
                                                this.previouslyHidden.push(module.identifier);
                                            } else {
                                                module.hide(1000);
                                    this.sendNotification('STAND_BY', { status: true, modules: this.previouslyHidden.slice(0) });
                      A Former User @sdetweil
                      First, this module doesn’t manage module’s showing and hiding itself. Of course I provided some recipe about it, but it’s better to be considered as a just example. The main purpose of this AMK2 is to give an ability about voice command and to relay it to other module. Not to control all things by AMK2 itself.
                      I think real job should be done by proper extern module. So If you have any good module(which is existed already or be planned to be made by yourself) to manage modules’ showing and hiding(There would be several modules already for this job), just transfer proper commands(notifications) to that module to do its job.
                        sdetweil @Guest
                        @Sean ok, thanks… still don’t understand recipe process design…
                        voice triggers command? command is some routine? run in context of module.js?
                          • To catch the specific voice order : use transcriptionHook or gAction. gAction is more natural way for user without side-effect.(something similar with Alexa Skill). But transcriptionHook is easier to make. Here is a just sample.
                          transcriptionHook : {
                            "MY_TEST_ORDER" : {
                              pattern: "execute order 66",
                              command: "MY_TEST_COMMAND"
                          This will hook your transcription from your speech when you say “Execute order 66”.
                          But this is just a kind of trigger. The real job(MY_TEST_COMMAND) needs to be defined.
                          • To define what to do when this order is triggered. : define command.
                          command: {
                            "MY_TEST_COMMAND": {
                              notificationExec: {
                                notification: "SHOW_ALERT",
                                payload: {
                                  message: "Yes, my lord."
                          This shows WHAT TO DO - to emit some notification(“SHOW_ALERT”) which alert module can understand and do as it’s job.
                          This is basic concept.
                            sdetweil @Guest
                            @Sean said in MMM-AssistantMk2:
                            well, SOME module MAY or may NOT understand and process
                              Yes. indeed. But it’s that module’s own business. Those kinds of modules are not designed to WORK TOGETHER with other modules. Sorry, but it’s not my fault.
                              In that case, you can execute module’s internal method by force. (Of course it is also not proper in some modules.)
                              command: {
                                  moduleExec: {
                                    module: ["alert"],
                                      module.show_alert({message:"Yes, my lord."}) // this code might make an error on real usage, but you can catch what I mean.
                              Anyway, you can build your own module for your specific job when there is no module to use.
                              • T
                                teitlebot
                                @sean
                                Im planning on using face recognition to show compliments when someone approaches mirror. Or maybe just PIR sensor. Either way, how would I get the compliment text to be said by Google? Would this be difficult?
                                  A Former User @teitlebot
                                  @teitlebot You need just TTS(MMM-TTS, MMM-GoogleTTS you can find). Not google Assistant. AI assistant normally be performed by CONVERSATION (text or vocal). face recognition is not CONVERSATION.
                                  If your face-recognition module can emit some notification, MMM-TTS/MMM-GoogleTTS can use that signal as a trigger for speech. (If you need, MMM-NotificationTrigger also could help to relay notification between modules.)
                                  ejay-ibmE 1 Reply Last reply Reply Quote 1
                                  • ejay-ibmE
                                    ejay-ibm Project Sponsor Module Developer @Guest
                                    @Sean @teitlebot
                                    Might sound stupid and not feasible at first but this is how I would do the trick.
                                    1st I would use a Notification from input ( camera , pir sensor)
                                    for PIR sensor it would be PRESENCE_DETECTED .
                                    Then I would trigger a command and in this command use the repeat after me function .
                                    So you can get voice output directly from the assistant saying “hello” when presence is detected .
                                    Then for facial recognition it’s just a matter of condition and what notification to send. for each notification a different repat after me.
                                    Does it make sense?
                                    Ejay
                                    ? 1 Reply Last reply Reply Quote 1
                                      A Former User @ejay-ibm
                                      @ejay-ibm @teitlebot
                                      Maybe possible.
                                      Converting PRESENCE_DETECTED to ASSISTANT_SAY with some payload(“Good morning sir”) could be. you can modify PIR module itself or use MMM-NotificationTrigger instead.
                                      T 1 Reply Last reply Reply Quote 1
                                      • B
                                        bryan_1 @Guest
                                        @Sean unfortunately it doesn’t help. I wonder, why only this SHOWMODULES doesn’t work but all other recipes do (include HIDEMODULES) :pensive_face:
                                        • T
                                          teitlebot @Guest
                                          @Sean @ejay-ibm
                                          so if I can use assistant_say why would I need to install TTS?
                                            @teitlebot
                                            Assistant_say is a kind of hack. It cannot be guaranteed to work properly at every case. And not for long text.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 21
                                            • 22
                                            • 14 / 22
