Problem update
Hello,
I would like an update but I have the following message:
Error: Your local changes to the following files will be overwritten:
modules / default / compliments / compliments.js
Please validate your changes or store them before you can merge.To update, I’m in the MaggicMirror directory and I run the git pull command
Thanks for your help. -
It looks like you made changes to your compliments.js. Did you add compliments to the module? It’s generally better to add them to the config.js instead.
I’d suggest to move your new compliments over to the config.js, undo the changes in the compliments.js and then run the update. -
@greda
If you dont need your changes in your compliment module, you can try following commands (in the folder you are trying to update viagit pull)git reset --hard git pull origin masterDo some post installations (if required).
AxLED
