    MMM-AssistantMk2 problems when using electron-rebuild
    40 Posts 6 Posters 21.6k Views 6 Watching
    • X Offline
      Xintium
      When I start my magic mirror I get node version error so I did as the instructions told me and tried using electron-rebuild. But when I use electron-rebuild I get this error:
      make: *** Ingen regel för att skapa målet ”Release/obj.target/grpc/deps/grpc/src/cpp/ext/filters/census/grpc_context.o”, som behövs av ”Release/obj.target/libgrpc.a”.  Stannar.
      make: Lämnar katalogen ”/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build”
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:180:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:12)
      gyp ERR! System Linux 4.14.52-v7+
      gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=2.0.0" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=grpc_node" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc" "--host=https://node-precompiled-binaries.grpc.io/" "--remote_path={name}/v1.14.0" "--package_name=electron-v2.0-linux-arm-glibc.tar.gz"
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
      gyp ERR! node -v v9.11.2
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      Failed with exit code: 1
          at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:277:84)
          at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:242:16)
          at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:201:26)
          at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
          at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
          at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
          at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
          at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:251:65)
          at SafeSubscriber.__tryOrSetError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:251:16)
          at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:191:27)
      Excuse the Swedish parts.
      What do I do to make it work?
      • ? Offline
        A Former User @Xintium
        @xintium
        It seems you’ve missed some dependencies or mismatched version (especially node-gyp)
        First, To make things simple, do these before install,
        sudo apt-get update
        sudo apt-get upgrade
        and try rebuilding again.
        If fails, remove whole MMM-AssistantMk2, and resintall from scratch.
        X 1 Reply Last reply Reply Quote 0
        • X Offline
          Xintium @Guest
          @sean should I run
          npm install --save-dev electron-rebuild
          ./node_modules/.bin/electron-rebuild
          In MMM-AssistantMk2 or in MagicMirror directory?
          • ? Offline
            @xintium
            In MMM-AssistankMk2 directory.
            X 2 Replies Last reply Reply Quote 0
            • X Offline
              Xintium @Guest
              @sean I get the same error as I shared abow
              • X Offline
                Xintium @Guest
                @sean This is what I get when I run magic mirror
                > magicmirror@2.4.1 start /home/pi/MagicMirror
                > sh run-start.sh
                Starting MagicMirror: v2.4.1
                Loading config ...
                Loading module helpers ...
                No helper found for module: MMM-darksky-hourly.
                Module helper loaded: MMM-MyCalendar
                WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                Expected directory: electron-v2.0-linux-arm-glibc
                Found: [node-v59-linux-arm-glibc]
                This problem can often be fixed by running "npm rebuild" on the current system
                Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
                App threw an error during load
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
                    at Module._compile (module.js:642:30)
                    at Object.Module._extensions..js (module.js:653:10)
                    at Module.load (module.js:561:32)
                    at tryModuleLoad (module.js:504:12)
                    at Function.Module._load (module.js:496:3)
                    at Module.require (module.js:586:17)
                    at require (internal/module.js:11:18)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12)
                { Error: Failed to load gRPC binary module because it was not installed for the current system
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:145:12) code: 'MODULE_NOT_FOUND' }
                Launching application.
                • ? Offline
                  @xintium
                  You need module to rebuild.
                  If you tried already, something was wrong so rebuilding process might have been failed.
                  Have you any suspicious messages during your rebuilds?
                  • X Offline
                    Xintium @Guest
                    @sean I get this message when trying to use electron-rebuild
                    gyp ERR! not ok
                    • ? Offline
                      @xintium
                      For confirmation,
                      1. Did you update & upgrade dependencies?
                      2. After that, did you remove MMM-AssistantMk2 directory and reinstall again?
                      Your error shows some of your dependencies are not updated to rebuild.
                      In that case, usually above steps are enough to fix.
                      Maybe this might be a help, but not sure.
                      sudo apt-get install build-essential
                      sudo npm install -g node-gyp
                      • L Offline
                        logen563
                        Hello!
                        I have this error, when trying to run the node_auth_test.js
                        Error: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21’ not found (required by /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/node-v48-linux-arm-glibc/grpc_node.node)
                        Can you give some advise how to solve this?
                        • ? Offline
                          A Former User @logen563
                          @logen563
                          Your GCC seems out of date.
                          Which RPI and OS are you using?
                          Try this, then reinstall again.
                          sudo apt-get update
                          • L Offline
                            logen563
                            Thanks for the quick replay!
                            Will try the reinstall, the update/upgrade didn’t solved the issue.
                            I’m using rpi3, with raspbian jessie light.
                            • ? Offline
                              @logen563
                              I have no experience about Jessie Lite. But by some researching, I’ve found this;
                              https://github.com/doublethinkco/cpp-ethereum-cross/issues/79
                              Suggested solution is to upgrade your gcc-5
                              And, As I know, Raspbian Stretch (next version of Jessie) has no problem about this.
                              • L Offline
                                logen563
                                Thanks for the replay, I will try that and will let you know :)
                                • L Offline
                                  logen563
                                  Thanks for the link! After updating with the stretch gcc-5, its working:) but I see I have to move on to the Stretch distro.
                                  • ? Offline
                                    @logen563
                                    If you leave details here, I’ll add it to github repository for others. Thanks.
                                      mrega
                                      Hi, im not expert!
                                      Someone can help me?
                                      Thanks!
                                      I have downgrade node js and npm;
                                      pi@raspberrypi:~/MagicMirror $ node -v
                                      v8.11.4
                                      pi@raspberrypi:~/MagicMirror $ npm -v
                                      5.6.0
                                      pi@raspberrypi:~/MagicMirror $ node-gyp -v
                                      v3.8.0
                                      Then
                                      Then -> Error!
                                      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/client_channel/resolver/sockaddr/sockaddr_resolver.o
                                      make: *** No hay ninguna regla para construir el objetivo ‘Release/obj.target/grpc/deps/grpc/src/cpp/ext/filters/census/grpc_context.o’, necesario para ‘Release/obj.target/libgrpc.a’. Alto.
                                      make: se sale del directorio ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
                                      gyp ERR! stack Error: make failed with exit code: 2
                                      gyp ERR! stack at emitTwo (events.js:126:13)
                                      gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                                      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                                      gyp ERR! System Linux 4.14.62-v7+
                                      gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp” “rebuild” “–target=2.0.0” “–arch=arm” “–dist-url=https://atom.io/download/electron” “–build-from-source” “–module_name=grpc_node” “–module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc” “–host=https://node-precompiled-binaries.grpc.io/” “–remote_path={name}/v1.14.1” “–package_name=electron-v2.0-linux-arm-glibc.tar.gz”
                                      gyp ERR! node -v v8.11.4
                                      gyp ERR! not ok
                                      Error: gyp info it worked if it ends with ok
                                      gyp info using node-gyp@3.8.0
                                      gyp info using node@8.11.4 | linux | arm
                                      gyp info spawn /usr/bin/python2
                                      gyp info spawn args [ ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/gyp/gyp_main.py’,
                                      gyp info spawn args ‘binding.gyp’,
                                      gyp info spawn args ‘-f’,
                                      gyp info spawn args ‘make’,
                                      gyp info spawn args ‘-I’,
                                      gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build/config.gypi’,
                                      gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/addon.gypi’,
                                      gyp info spawn args ‘/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/common.gypi’,
                                      gyp info spawn args ‘-Dlibrary=shared_library’,
                                      gyp info spawn args ‘-Dvisibility=default’,
                                      gyp info spawn args ‘-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0’,
                                      gyp info spawn args ‘-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp’,
                                      gyp info spawn args ‘-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/<(target_arch)/iojs.lib’,
                                      gyp info spawn args ‘-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc’,
                                      gyp info spawn args ‘-Dnode_engine=v8’,
                                      gyp info spawn args ‘–depth=.’,
                                      gyp info spawn args ‘–no-parallel’,
                                      gyp info spawn args ‘–generator-output’,
                                      gyp info spawn args ‘build’,
                                      gyp info spawn args ‘-Goutput_dir=.’ ]
                                      gyp info spawn make
                                      gyp info spawn args [ ‘BUILDTYPE=Release’, ‘-C’, ‘build’ ]
                                      make: se entra en el directorio ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
                                      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
                                      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/avl/avl.o
                                      gyp ERR! not ok
                                      Something idea whats wrong?
                                      Thanks!
                                      • ? Offline
                                        A Former User @mrega
                                        @mrega
                                        Dear buddy,
                                        After some research, I’ve found something. a few days ago, grpc was updated, but proper binaries are not provided yet. That’s why rebuild-from-source doesn’t work.
                                        Here is an urgent but experimental fix.
                                        I cannot give a guarantee to work, but think there is worthy of trying.
                                        first,
                                        cd node_modules
                                        rm -rf grpc
                                        cd ..
                                        npm install @grpc/grpc-js
                                        I wish grpc release proper target binaries ASAP.
                                        • Y Offline
                                          yep_DD
                                          Hi @Sean
                                          I have the same problem trying to build from scratch. It fails at grpc, I tried your solution but is the same
                                          gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=2.0.0" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=grpc_node" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc" "--host=https://node-precompiled-binaries.grpc.io/" "--remote_path={name}/v1.14.1" "--package_name=electron-v2.0-linux-arm-glibc.tar.gz"
                                          gyp ERR! not ok
                                          • ? Offline
                                            A Former User @yep_DD
                                            @yep_dd
                                            Here is the answer from grpc-node community
                                            https://github.com/grpc/grpc-node/issues/507#issuecomment-414465022
                                            So, wait for a while… It’s not the fault of my module… T_T
