    MMM-AssistantMk2 problems when using electron-rebuild
    40 Posts 6 Posters 19.1k Views 6 Watching
    • Y Offline
      yep_DD
      @sean said in MMM-AssistantMk2 problems when using electron-rebuild:
      rm -rf grpc
      Hi @Sean,
      cool that helps. You you just advice for some of the not so advanced npm and node users how to downgrade?
      Thank you so much,
      Stephan
      • ? Offline
        A Former User @yep_DD
        @yep_dd
        Currently, I’m not in front of my device, so I write this without test.
         npm install [package]@[version]
        That is a usual form.
        Thus,
        cd ~/MagicMirror/modules/MMM-AssistantMk2
        rm -rf ./node_modules/grpc
        npm install grpc@1.13
        would work, I think.
          dvbit
          if anybody needs a working raspie3b+ image with hotword/notification/assistant installed drop a pm
          • Y Offline
            yep_DD
            @Sean
            works like a charm, thank you
            • Y Offline
              yep_DD
              @Sean
              off topic: is there a way to set the audio output (Device / Program) routing like “record” for the mic?
              ? 2 Replies Last reply Reply Quote 0
              • ? Offline
                This post is deleted!
                • ? Offline
                  @yep_dd
                  I didn’t make it configurable much. But you can modify ‘node_helper.js’ by yourself
                  var speaker = new Speaker({
                  channels: 1,
                  sampleRate: cfgInstance.conversation.audio.sampleRateOut,
                  You can add here ‘device:”hw:1,0”,”. I’ll fix them to be configurable next update.
                  • Y Offline
                    yep_DD
                    @Sean
                    cool, works, thank you so much. Would you know where youtube audio is configured? Because that still uses the standard.
                    • ? Offline
                      @yep_dd I don’t know about that, sorry. :| I think you should adjust your mixer (alsa? or pulse?)
                      • Y Offline
                        yep_DD
                        @Sean
                        correct, works. Modified /usr/share/alsa/alsa.conf for the default sound card and added a “record” for MMM-Hotkey so it wouldn’t use that as default: working just fine.
                        Just stuttering, the audio output as well as video. Let’s see why… when audio is played through the 3.5mm jack it works fine.
                        • 3 / 4
