    MMM-AssistantMk2 problems when using electron-rebuild
    40 Posts 6 Posters 22.1k Views 6 Watching
    • L Offline
      logen563
      Thanks for the quick replay!
      Will try the reinstall, the update/upgrade didn’t solved the issue.
      I’m using rpi3, with raspbian jessie light.
        A Former User @logen563
        @logen563
        I have no experience about Jessie Lite. But by some researching, I’ve found this;
        https://github.com/doublethinkco/cpp-ethereum-cross/issues/79
        Suggested solution is to upgrade your gcc-5
        And, As I know, Raspbian Stretch (next version of Jessie) has no problem about this.
        • L Offline
          logen563
          Thanks for the replay, I will try that and will let you know :)
          • L Offline
            logen563
            Thanks for the link! After updating with the stretch gcc-5, its working:) but I see I have to move on to the Stretch distro.
              @logen563
              If you leave details here, I’ll add it to github repository for others. Thanks.
                mrega
                Hi, im not expert!
                Someone can help me?
                Thanks!
                I have downgrade node js and npm;
                pi@raspberrypi:~/MagicMirror $ node -v
                v8.11.4
                pi@raspberrypi:~/MagicMirror $ npm -v
                5.6.0
                pi@raspberrypi:~/MagicMirror $ node-gyp -v
                v3.8.0
                Then
                npm install --save-dev electron-rebuild
                ./node_modules/.bin/electron-rebuild
                Then -> Error!
                CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/client_channel/resolver/sockaddr/sockaddr_resolver.o
                make: *** No hay ninguna regla para construir el objetivo ‘Release/obj.target/grpc/deps/grpc/src/cpp/ext/filters/census/grpc_context.o’, necesario para ‘Release/obj.target/libgrpc.a’. Alto.
                make: se sale del directorio ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
                gyp ERR! build error
                gyp ERR! stack Error: make failed with exit code: 2
                gyp ERR! stack at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:262:23)
                gyp ERR! stack at emitTwo (events.js:126:13)
                gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                gyp ERR! System Linux 4.14.62-v7+
                gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp” “rebuild” “–target=2.0.0” “–arch=arm” “–dist-url=https://atom.io/download/electron” “–build-from-source” “–module_name=grpc_node” “–module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc” “–host=https://node-precompiled-binaries.grpc.io/” “–remote_path={name}/v1.14.1” “–package_name=electron-v2.0-linux-arm-glibc.tar.gz”
                gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
                gyp ERR! node -v v8.11.4
                gyp ERR! node-gyp -v v3.8.0
                gyp ERR! not ok
                Failed with exit code: 1
                Error: gyp info it worked if it ends with ok
                gyp info using node-gyp@3.8.0
                gyp info using node@8.11.4 | linux | arm
                gyp info spawn /usr/bin/python2
                gyp info spawn args [ ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/gyp/gyp_main.py’,
                gyp info spawn args ‘binding.gyp’,
                gyp info spawn args ‘-f’,
                gyp info spawn args ‘make’,
                gyp info spawn args ‘-I’,
                gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build/config.gypi’,
                gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/addon.gypi’,
                gyp info spawn args ‘/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/common.gypi’,
                gyp info spawn args ‘-Dlibrary=shared_library’,
                gyp info spawn args ‘-Dvisibility=default’,
                gyp info spawn args ‘-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0’,
                gyp info spawn args ‘-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp’,
                gyp info spawn args ‘-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/<(target_arch)/iojs.lib’,
                gyp info spawn args ‘-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc’,
                gyp info spawn args ‘-Dnode_engine=v8’,
                gyp info spawn args ‘–depth=.’,
                gyp info spawn args ‘–no-parallel’,
                gyp info spawn args ‘–generator-output’,
                gyp info spawn args ‘build’,
                gyp info spawn args ‘-Goutput_dir=.’ ]
                gyp info spawn make
                gyp info spawn args [ ‘BUILDTYPE=Release’, ‘-C’, ‘build’ ]
                make: se entra en el directorio ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
                CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
                CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/avl/avl.o
                gyp ERR! not ok
                at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:277:84)
                at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:242:16)
                at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:201:26)
                at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
                at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
                at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
                at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
                at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:251:65)
                at SafeSubscriber.__tryOrSetError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:251:16)
                at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:191:27)
                Something idea whats wrong?
                Thanks!
                  A Former User @mrega
                  @mrega
                  Dear buddy,
                  After some research, I’ve found something. a few days ago, grpc was updated, but proper binaries are not provided yet. That’s why rebuild-from-source doesn’t work.
                  Here is an urgent but experimental fix.
                  I cannot give a guarantee to work, but think there is worthy of trying.
                  first,
                  cd node_modules
                  rm -rf grpc
                  cd ..
                  npm install @grpc/grpc-js
                  I wish grpc release proper target binaries ASAP.
                  • Y Offline
                    yep_DD
                    Hi @Sean
                    I have the same problem trying to build from scratch. It fails at grpc, I tried your solution but is the same
                    gyp ERR! stack Error: `make` failed with exit code: 2
                    gyp ERR! stack     at ChildProcess.emit (events.js:180:13)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:12)
                    gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=2.0.0" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=grpc_node" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc" "--host=https://node-precompiled-binaries.grpc.io/" "--remote_path={name}/v1.14.1" "--package_name=electron-v2.0-linux-arm-glibc.tar.gz"
                    gyp ERR! node -v v9.11.2
                    gyp ERR! not ok
                      A Former User @yep_DD
                      @yep_dd
                      Here is the answer from grpc-node community
                      https://github.com/grpc/grpc-node/issues/507#issuecomment-414465022
                      So, wait for a while… It’s not the fault of my module… T_T
                      • Y Offline
                        yep_DD
                        @sean said in MMM-AssistantMk2 problems when using electron-rebuild:
                        rm -rf grpc
                        Hi @Sean,
                        cool that helps. You you just advice for some of the not so advanced npm and node users how to downgrade?
                        Thank you so much,
                        Stephan
                          @yep_dd
                          Currently, I’m not in front of my device, so I write this without test.
                           npm install [package]@[version]
                          That is a usual form.
                          Thus,
                          cd ~/MagicMirror/modules/MMM-AssistantMk2
                          rm -rf ./node_modules/grpc
                          npm install grpc@1.13
                          would work, I think.
                            dvbit
                            if anybody needs a working raspie3b+ image with hotword/notification/assistant installed drop a pm
                            • Y Offline
                              yep_DD
                              @Sean
                              works like a charm, thank you
                              • Y Offline
                                yep_DD
                                @Sean
                                off topic: is there a way to set the audio output (Device / Program) routing like “record” for the mic?
                                    @yep_dd
                                    I didn’t make it configurable much. But you can modify ‘node_helper.js’ by yourself
                                    var speaker = new Speaker({
                                    channels: 1,
                                    sampleRate: cfgInstance.conversation.audio.sampleRateOut,
                                    You can add here ‘device:”hw:1,0”,”. I’ll fix them to be configurable next update.
                                    • Y Offline
                                      yep_DD
                                      @Sean
                                      cool, works, thank you so much. Would you know where youtube audio is configured? Because that still uses the standard.
                                        @yep_dd I don’t know about that, sorry. :| I think you should adjust your mixer (alsa? or pulse?)
                                        • Y Offline
                                          yep_DD
                                          @Sean
                                          correct, works. Modified /usr/share/alsa/alsa.conf for the default sound card and added a “record” for MMM-Hotkey so it wouldn’t use that as default: working just fine.
                                          Just stuttering, the audio output as well as video. Let’s see why… when audio is played through the 3.5mm jack it works fine.
                                          • Y Offline
                                            yep_DD
                                            @Sean
                                            what is your CPU usage when playing youtube videos and using the google assistent? I am using OpenGL for rendering… but videos and audio via HDMiIseems to stutter
