    MMM-AssistantMk2 problems when using electron-rebuild
    40 Posts 6 Posters 22.0k Views 6 Watching
      A Former User @yep_DD
      @yep_dd
      Here is the answer from grpc-node community
      https://github.com/grpc/grpc-node/issues/507#issuecomment-414465022
      So, wait for a while… It’s not the fault of my module… T_T
      • Y Offline
        yep_DD
        @sean said in MMM-AssistantMk2 problems when using electron-rebuild:
        rm -rf grpc
        Hi @Sean,
        cool that helps. You you just advice for some of the not so advanced npm and node users how to downgrade?
        Thank you so much,
        Stephan
          @yep_dd
          Currently, I’m not in front of my device, so I write this without test.
           npm install [package]@[version]
          That is a usual form.
          Thus,
          cd ~/MagicMirror/modules/MMM-AssistantMk2
          rm -rf ./node_modules/grpc
          npm install grpc@1.13
          would work, I think.
            dvbit
            if anybody needs a working raspie3b+ image with hotword/notification/assistant installed drop a pm
            • Y Offline
              yep_DD
              @Sean
              works like a charm, thank you
              • Y Offline
                yep_DD
                @Sean
                off topic: is there a way to set the audio output (Device / Program) routing like “record” for the mic?
                    @yep_dd
                    I didn’t make it configurable much. But you can modify ‘node_helper.js’ by yourself
                    var speaker = new Speaker({
                    channels: 1,
                    sampleRate: cfgInstance.conversation.audio.sampleRateOut,
                    You can add here ‘device:”hw:1,0”,”. I’ll fix them to be configurable next update.
                    • Y Offline
                      yep_DD
                      @Sean
                      cool, works, thank you so much. Would you know where youtube audio is configured? Because that still uses the standard.
                        @yep_dd I don’t know about that, sorry. :| I think you should adjust your mixer (alsa? or pulse?)
                        • Y Offline
                          yep_DD
                          @Sean
                          correct, works. Modified /usr/share/alsa/alsa.conf for the default sound card and added a “record” for MMM-Hotkey so it wouldn’t use that as default: working just fine.
                          Just stuttering, the audio output as well as video. Let’s see why… when audio is played through the 3.5mm jack it works fine.
                          • Y Offline
                            yep_DD
                            @Sean
                            what is your CPU usage when playing youtube videos and using the google assistent? I am using OpenGL for rendering… but videos and audio via HDMiIseems to stutter
                              dvbit @yep_DD
                              @yep_dd I am using rpi3b+ sound output via HDMI.no stutter.
                                A Former User @dvbit
                                @dvbit Frankly I use mainly Asus Tinker Board. I couldn’t satisfied with performance of RPI3,
                                anyway, usually, with BT speaker, RPI3 has good enough sound. For video, I think non-HD youtube video can be played enough.
                                  dvbit @Guest
                                  @sean yes I saw your posts and realized it. Also had a look and thought about getting an asus but finally went for raspb3 for gpio support (at least in my readings it was saying it was suboptimal…)
                                  I might give an AEON with atom (that I have) a ride if more power is needed.
                                  PS: I went through the google sdk to understand current capabilities (especially in my language) and saw the output limitations you mentionned.
                                  I could not find a list of supported features compared to smartphone assitant. do you have any pointer? tx
                                    @dvbit For screenOutput? At this moment, Nothing. It is experimental stage. Screenoutput is too tight binded with specific hw. By example, original search results of video is not playable. It is assumed to activate app on smartTv. I had to parse static html output to catch youtube Video Id.
                                    • Y Offline
                                      yep_DD
                                      I switched back to headphone jack output and it is the same. Video and sound stutters.
                                      • Y Offline
                                        yep_DD
                                        @Sean
                                        Tinker Board looks promising… will take me a while to set up and I am working the next couple of days, let’s see :).
                                        • Y Offline
                                          yep_DD
                                          @Sean I’ve just tried the google voice hat with your module, it works fine and a lot smoothe for some reason. I disabled the BCM soundcard and no stuttering except of the first google assistent replies right after boot up. Still on RPI3, let’s see with tinker board.
                                          • Y Offline
                                            yep_DD
                                            one more thing, I noticed when using the newsfeed module it stutters when fading to the next headline, can anyone confirm that? Performance is 10000x better with TinkerBoard than with PI3
