    MMM-AssistantMk2 problems when using electron-rebuild
    40 Posts 6 Posters 22.7k Views 6 Watching
      mrega
      Hi, im not expert!
      Someone can help me?
      Thanks!
      I have downgrade node js and npm;
      pi@raspberrypi:~/MagicMirror $ node -v
      v8.11.4
      pi@raspberrypi:~/MagicMirror $ npm -v
      5.6.0
      pi@raspberrypi:~/MagicMirror $ node-gyp -v
      v3.8.0
      Then
      npm install --save-dev electron-rebuild
      ./node_modules/.bin/electron-rebuild
      Then -> Error!
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/client_channel/resolver/sockaddr/sockaddr_resolver.o
      make: *** No hay ninguna regla para construir el objetivo ‘Release/obj.target/grpc/deps/grpc/src/cpp/ext/filters/census/grpc_context.o’, necesario para ‘Release/obj.target/libgrpc.a’. Alto.
      make: se sale del directorio ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack at emitTwo (events.js:126:13)
      gyp ERR! stack at ChildProcess.emit (events.js:214:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
      gyp ERR! System Linux 4.14.62-v7+
      gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp” “rebuild” “–target=2.0.0” “–arch=arm” “–dist-url=https://atom.io/download/electron” “–build-from-source” “–module_name=grpc_node” “–module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc” “–host=https://node-precompiled-binaries.grpc.io/” “–remote_path={name}/v1.14.1” “–package_name=electron-v2.0-linux-arm-glibc.tar.gz”
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
      gyp ERR! node -v v8.11.4
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      Failed with exit code: 1
      Error: gyp info it worked if it ends with ok
      gyp info using node-gyp@3.8.0
      gyp info using node@8.11.4 | linux | arm
      gyp info spawn /usr/bin/python2
      gyp info spawn args [ ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/gyp/gyp_main.py’,
      gyp info spawn args ‘binding.gyp’,
      gyp info spawn args ‘-f’,
      gyp info spawn args ‘make’,
      gyp info spawn args ‘-I’,
      gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build/config.gypi’,
      gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/addon.gypi’,
      gyp info spawn args ‘/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/common.gypi’,
      gyp info spawn args ‘-Dlibrary=shared_library’,
      gyp info spawn args ‘-Dvisibility=default’,
      gyp info spawn args ‘-Dnode_root_dir=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0’,
      gyp info spawn args ‘-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp’,
      gyp info spawn args ‘-Dnode_lib_file=/home/pi/.electron-gyp/.node-gyp/iojs-2.0.0/<(target_arch)/iojs.lib’,
      gyp info spawn args ‘-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc’,
      gyp info spawn args ‘-Dnode_engine=v8’,
      gyp info spawn args ‘–depth=.’,
      gyp info spawn args ‘–no-parallel’,
      gyp info spawn args ‘–generator-output’,
      gyp info spawn args ‘build’,
      gyp info spawn args ‘-Goutput_dir=.’ ]
      gyp info spawn make
      gyp info spawn args [ ‘BUILDTYPE=Release’, ‘-C’, ‘build’ ]
      make: se entra en el directorio ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/avl/avl.o
      gyp ERR! not ok
      at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:277:84)
      at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:242:16)
      at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:201:26)
      at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
      at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
      at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:132:26)
      at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:106:18)
      at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:251:65)
      at SafeSubscriber.__tryOrSetError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:251:16)
      at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/Subscriber.js:191:27)
      Something idea whats wrong?
      Thanks!
        A Former User @mrega
        @mrega
        Dear buddy,
        After some research, I’ve found something. a few days ago, grpc was updated, but proper binaries are not provided yet. That’s why rebuild-from-source doesn’t work.
        Here is an urgent but experimental fix.
        I cannot give a guarantee to work, but think there is worthy of trying.
        first,
        cd node_modules
        rm -rf grpc
        cd ..
        npm install @grpc/grpc-js
        I wish grpc release proper target binaries ASAP.
        • Y
          yep_DD
          Hi @Sean
          I have the same problem trying to build from scratch. It fails at grpc, I tried your solution but is the same
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.emit (events.js:180:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:12)
          gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=2.0.0" "--arch=arm" "--dist-url=https://atom.io/download/electron" "--build-from-source" "--module_name=grpc_node" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc" "--host=https://node-precompiled-binaries.grpc.io/" "--remote_path={name}/v1.14.1" "--package_name=electron-v2.0-linux-arm-glibc.tar.gz"
          gyp ERR! node -v v9.11.2
          gyp ERR! not ok
            A Former User @yep_DD
            @yep_dd
            Here is the answer from grpc-node community
            https://github.com/grpc/grpc-node/issues/507#issuecomment-414465022
            So, wait for a while… It’s not the fault of my module… T_T
            • Y
              yep_DD
              @sean said in MMM-AssistantMk2 problems when using electron-rebuild:
              rm -rf grpc
              Hi @Sean,
              cool that helps. You you just advice for some of the not so advanced npm and node users how to downgrade?
              Thank you so much,
              Stephan
                @yep_dd
                Currently, I’m not in front of my device, so I write this without test.
                 npm install [package]@[version]
                That is a usual form.
                Thus,
                cd ~/MagicMirror/modules/MMM-AssistantMk2
                rm -rf ./node_modules/grpc
                npm install grpc@1.13
                would work, I think.
                  dvbit
                  if anybody needs a working raspie3b+ image with hotword/notification/assistant installed drop a pm
                  • Y
                    yep_DD
                    @Sean
                    works like a charm, thank you
                    • Y
                      yep_DD
                      @Sean
                      off topic: is there a way to set the audio output (Device / Program) routing like “record” for the mic?
                          @yep_dd
                          I didn’t make it configurable much. But you can modify ‘node_helper.js’ by yourself
                          var speaker = new Speaker({
                          channels: 1,
                          sampleRate: cfgInstance.conversation.audio.sampleRateOut,
                          You can add here ‘device:”hw:1,0”,”. I’ll fix them to be configurable next update.
                          • Y
                            yep_DD
                            @Sean
                            cool, works, thank you so much. Would you know where youtube audio is configured? Because that still uses the standard.
                              @yep_dd I don’t know about that, sorry. :| I think you should adjust your mixer (alsa? or pulse?)
                              • Y
                                yep_DD
                                @Sean
                                correct, works. Modified /usr/share/alsa/alsa.conf for the default sound card and added a “record” for MMM-Hotkey so it wouldn’t use that as default: working just fine.
                                Just stuttering, the audio output as well as video. Let’s see why… when audio is played through the 3.5mm jack it works fine.
                                • Y
                                  yep_DD
                                  @Sean
                                  what is your CPU usage when playing youtube videos and using the google assistent? I am using OpenGL for rendering… but videos and audio via HDMiIseems to stutter
                                    dvbit @yep_DD
                                    @yep_dd I am using rpi3b+ sound output via HDMI.no stutter.
                                      A Former User @dvbit
                                      @dvbit Frankly I use mainly Asus Tinker Board. I couldn’t satisfied with performance of RPI3,
                                      anyway, usually, with BT speaker, RPI3 has good enough sound. For video, I think non-HD youtube video can be played enough.
                                        dvbit @Guest
                                        @sean yes I saw your posts and realized it. Also had a look and thought about getting an asus but finally went for raspb3 for gpio support (at least in my readings it was saying it was suboptimal…)
                                        I might give an AEON with atom (that I have) a ride if more power is needed.
                                        PS: I went through the google sdk to understand current capabilities (especially in my language) and saw the output limitations you mentionned.
                                        I could not find a list of supported features compared to smartphone assitant. do you have any pointer? tx
                                          @dvbit For screenOutput? At this moment, Nothing. It is experimental stage. Screenoutput is too tight binded with specific hw. By example, original search results of video is not playable. It is assumed to activate app on smartTv. I had to parse static html output to catch youtube Video Id.
                                          • Y
                                            yep_DD
                                            I switched back to headphone jack output and it is the same. Video and sound stutters.
