Modules not loading
Hi!
iv’e recently freshly installed my RPI3
now, i installed MM, configured it as it should be without errors or bugs (hopfully) using the help of http://jshint.com/ wich doesnt shows any problems, but when the MM loads up, no modules are loaded except from the calendar and the clock.i have only installed MMM-Tools
https://github.com/eouia/MMM-Tools
as a3rd party module. but none of the oters work with or without it…
what have i done wrong?heres the thing:
ive uninstalled MM and installed it again, and without my changes to the config file it works perfectly. after a change it (with the one below), all modules stop working except for the calendar and clock.
any ideas?/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "metric", modules: [ // new module { module: "alert", }, // new module { module: "updatenotification", position: "top_bar" }, // new module { module: "clock", position: "top_left" }, // new module { module: "calendar", header: "X", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "X" } ] } }, // new module { module: "calendar", header: "X", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "X" } ] } }, // new module { module: "compliments", position: "" //lower_third }, { module: "currentweather", position: "top_right", config: { location: "X", locationID: "X", //ID from http://www.openweathermap.org/help/city_list.txt appid: "X" } }, // new module { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "X", locationID: "X", //ID from http://www.openweathermap.org/help/city_list.txt appid: "X" } }, // new module { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "X", url: "X" } ], showSourceTitle: true, showPublishDate: true } }, // new module { module: 'MMM-Tools', position: 'bottom_right', config: { device : "RPI", // "ATB" is also available refresh_interval_ms : 1000, warning_interval_ms : 1000 * 60 * 5, enable_warning : true, warning : { CPU_TEMPERATURE : 65, GPU_TEMPERATURE : 65, CPU_USAGE : 85, STORAGE_USED_PERCENT : 80, MEMORY_USED_PERCENT : 80 } } }, // new module ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
Looks nice.
I like the// new module
Try this:
{ module: "compliments", position: "lower_third" },
And you have entered the module calendar twice, but that should not lead to an error.
This post is deleted!
haha glad you liked it… the code looks very scrambled without it in my opinion …
And i dont want the compliments module at all…but for the “sport” in it, i tried to do it with the compliment, and still none… just the calendar and clock.
calendar is twice because i use 2 calendars (private&work) but they both work and worked just fineany further ideas?
with the original config file everything works perfectly. after i change even a bit or even the RSS source, same error.
