    Dumb Question
    6 Posts 2 Posters 2.8k Views 2 Watching
    • ? Offline
      A Former User
      This post is deleted!
      • ? Offline
        A Former User
        Use pm2 show <id|name> to get more details about an app
        NA-3:~ …$ pm2 start mm.sh
        [PM2][ERROR] script not found : /Users/…/mm.sh
        Tried that…
        alt textried that…
        • ? Offline
          A Former User
          alt text
          • ? Offline
            A Former User
            npm ERR! Darwin 13.4.0
            npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
            npm ERR! node v6.8.0
            npm ERR! npm v3.10.8
            npm ERR! code ELIFECYCLE
            npm ERR! magicmirror@2.0.0 start: electron js/electron.js
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
            npm ERR! If you do, this is most likely a problem with the magicmirror package,
            npm ERR! not with npm itself.
            npm ERR! electron js/electron.js
            npm ERR! npm bugs magicmirror
            npm ERR! Or if that isn’t available, you can get their info via:
            npm ERR! npm owner ls magicmirror
            npm ERR! /Users/…/MagicMirror/npm-debug.log
            NA-3:MagicMirror …$
            • bheplerB Offline
              bhepler Module Developer @Guest
              @wjdw87 Make sure that you created the mm.sh script as part of the pm2 process. Run ls -lh ~/ and see if mm.sh is one of the files.
              There should be an entry that looks like this:
              -rwxr-xr-x  1 pi pi   40 Oct 17 18:46 mm.sh
              • ? Offline
                A Former User
                Thanks since worked it out, was meant to remove the topic, but thanks for answering (actually i’m currently playing on the mac, awaiting the hardware (RPi).
