Recurring events Calender
20 Posts 5 Posters 6.0k Views 5 Watching
    Mr_Moore
    Having problems with recurring events for Calender. For the recurring events, the time will gets wrong. Seems like it’s UTC time zone. In Google Calendar, everything is right, but on the Magic Mirror it shows the event two hours later then planned. If I enter an individual event, it will be the correct time.
    Anyone who knows what could be wrong?
    			header: "HallonKalender",
    					timeFormat: 'dateheaders',
    					getRelative: 0,
    					urgency: 0,
    						symbol: "calendar-check-o ",
    						url: "https://calendar.google.com/calendar/ical/XXXXXXXXXXXXX/basic.ics"
    B 1 Reply Last reply Aug 18, 2018, 2:24 PM Reply Quote 0
      bhepler Module Developer @Mr_Moore
      @mr_moore - Just to be sure, you did set the location of your Pi using the raspi-config tool or going through the UI system configuration? That’s a likely culprit.
      By default, the Raspbian OS thinks it is British. I have to set the time zone, language and keyboard first thing after every OS flash. If I don’t, the keyboard special characters are all off, I can’t get my passwords to work, and it thinks football is played without helmets.
        Mr_Moore
        @bhepler - I have the right time zone. The clock is correct. And if i have a one time appointment in the Google Calender it wil show the correct time at the MM. It is only when i have recurring events that it will show two hours wrong.
        B 1 Reply Last reply Aug 24, 2018, 12:52 PM Reply Quote 0
          @mr_moore - Hmm. Can you check the recurring events through Google’s interface and make sure the time zones on those events is correct?
            Mr_Moore
            @bhepler everything looks ok in Google Calender. See snapshots from Google and Mirror. Two reccuring events and one with only this day.
            M 1 Reply Last reply Sep 28, 2020, 3:32 PM Reply Quote 0
              MajorC Project Sponsor @Mr_Moore
              @Mr_Moore said in Recurring events Calender:
              Did you solve this problem? I have the same one at the moment.
              S 1 Reply Last reply Sep 28, 2020, 4:48 PM Reply Quote 0
                sdetweil @MajorC
                @MajorC did u install the temp calendar fixes from the troubleshooting section?
                  Sorry, what? Can you provide me a link?
                  S 1 Reply Last reply Sep 28, 2020, 8:52 PM Reply Quote 0
                    sdetweil @MajorC
                    @MajorC temp calendar fixes from the troubleshooting section?
                    the troubleshooting section of the forum, the topics are pinned to the top
                    note
                    these temp fixes were for 2.12
                    all the fixes are now in 2.13 (or the latest develop branch, see below)
                    D 1 Reply Last reply Oct 11, 2020, 8:41 PM Reply Quote 0
                      dawookie1979 @sdetweil
                      @sdetweil did you manage to fix this? I have similar issues, mine being 1 hour early ;)
                      S 1 Reply Last reply Oct 11, 2020, 8:51 PM Reply Quote 0
