SSH startup
16 Posts 8 Posters 16.4k Views 8 Watching
  • G Offline
    geeflaxx
    thanks, but they don’t work
    i create the script, and i saved it in the pm2
    but if i restart my magic mirror they begin in the desktop
    and if i use ‘pm2 start mm.sh’
    they go to the mirror
    with the command ‘pm2 show mm’ i see that is a x in the field “watch & reload”
    what now ?
    • K Offline
      KirAsh4 Moderator
      Then you didn’t do it correctly. Did you launch it, then save the task? You have to follow the steps one by one. Please go back and start from the top and do it again.
      • G Offline
        geeflaxx
        http://www.bilder-upload.eu/show.php?file=e77336-1477512295.png
        i only did it
        • K Offline
          KirAsh4 Moderator
          There’s a glaring instruction right there on the screen that you did not follow. When you typed in pm2 startup it clearly told you what you need to do, which I don’t see anywhere in your command log. I’m sorry, but if you can’t follow directions given to you, there is really not a whole lot anyone can do to help you. The instructions are there for you to follow, please do that.
            Stehman07 @bhepler
            @bhepler I try to enter ‘display_rotate=1’ in the config.txt file in the boot folder. I try to save the file and overwrite the previous version of the file to only get the message “can’t open file to write”. Where am I going wrong on this?
            Y 1 Reply Last reply Nov 25, 2016, 7:31 PM Reply Quote 0
            • Y Offline
              yawns Moderator @Stehman07
              @Stehman07
              you need to edit the file as root, the normal user pi does not have sufficient rights.
              Run sudo nano /boot/config.txt instead
