    SSH startup
    16 Posts 8 Posters 19.5k Views 8 Watching
    • CatoC
      Cato Module Developer @djbenny07
      @djbenny07 Try to add "DISPLAY=:0’ in front of your command. Do you really need “sudo”?
      • AlvingerA
        Alvinger
        Also make sure that you enable X forwarding in the ssh call, e.g. ssh -X user@host.
        • KirAsh4K
          KirAsh4 Moderator
          DISPLAY=:0 is a must when attempting to start MM through an SSH connection, otherwise it simply doesn’t have a clue what display to use, the one you’re sitting at, or the one on the rpi?
          X-Forwarding is not required nor necessary for a simple ssh login, startup, and exit.
          • G
            geeflaxx
            i could you say that i don’t have the electron order.
            and display=:0 isn’t it for vertical view?
            http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png
            http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png
            bheplerB 1 Reply Last reply
            • bheplerB
              bhepler Module Developer @geeflaxx
              @geeflaxx The display=:0 parameter is to send the output of the electron process to the monitor attached to your Raspberry Pi.
              Rotating the display is done by editing the /boot/config.txt file and adding the line display_rotate=1
              • KirAsh4K
                KirAsh4 Moderator
                The ‘DISPLAY=:0’ bit is simply telling the system (in this case the rpi), which monitor it should use, in this case, the attached one.
                For rotation, using ‘display_rotate’ you can tell the OS how to rotate the output:
                display_rotate=0           Normal
                display_rotate=1           90 degrees
                display_rotate=2          180 degrees
                display_rotate=3          270 degrees
                display_rotate=0x10000    horizontal flip
                display_rotate=0x20000    vertical flip
                • G
                  geeflaxx
                  a little question:
                  how i can delete my “desktop” and start with my npm (so i wanna after a restart direct to my npm not on my desktop)?
                  • KirAsh4K
                    KirAsh4 Moderator
                    You can’t. You need the desktop to run electron which is what displays the mirror. What you can do, is run an automatic (re)start of the mirror. For instructions, please visit https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                    • G
                      geeflaxx
                      thanks, but they don’t work
                      i create the script, and i saved it in the pm2
                      but if i restart my magic mirror they begin in the desktop
                      and if i use ‘pm2 start mm.sh’
                      they go to the mirror
                      with the command ‘pm2 show mm’ i see that is a x in the field “watch & reload”
                      what now ?
                      • KirAsh4K
                        KirAsh4 Moderator
                        Then you didn’t do it correctly. Did you launch it, then save the task? You have to follow the steps one by one. Please go back and start from the top and do it again.
                        • G
                          geeflaxx
                          http://www.bilder-upload.eu/show.php?file=e77336-1477512295.png
                          i only did it
                          • KirAsh4K
                            KirAsh4 Moderator
                            There’s a glaring instruction right there on the screen that you did not follow. When you typed in pm2 startup it clearly told you what you need to do, which I don’t see anywhere in your command log. I’m sorry, but if you can’t follow directions given to you, there is really not a whole lot anyone can do to help you. The instructions are there for you to follow, please do that.
                              Stehman07 @bhepler
                              @bhepler I try to enter ‘display_rotate=1’ in the config.txt file in the boot folder. I try to save the file and overwrite the previous version of the file to only get the message “can’t open file to write”. Where am I going wrong on this?
                              yawnsY 1 Reply Last reply
                              • yawnsY
                                yawns Moderator @Stehman07
                                @Stehman07
                                you need to edit the file as root, the normal user pi does not have sufficient rights.
                                Run sudo nano /boot/config.txt instead
