    SSH startup
    16 Posts 8 Posters 18.1k Views 8 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      DISPLAY=:0 is a must when attempting to start MM through an SSH connection, otherwise it simply doesn’t have a clue what display to use, the one you’re sitting at, or the one on the rpi?
      X-Forwarding is not required nor necessary for a simple ssh login, startup, and exit.
      • G Offline
        geeflaxx
        i could you say that i don’t have the electron order.
        and display=:0 isn’t it for vertical view?
        http://www.bilder-upload.eu/show.php?file=df2e81-1477496516.png
        http://www.bilder-upload.eu/show.php?file=64ba61-1477496550.png
        • bheplerB Offline
          bhepler Module Developer @geeflaxx
          @geeflaxx The display=:0 parameter is to send the output of the electron process to the monitor attached to your Raspberry Pi.
          Rotating the display is done by editing the /boot/config.txt file and adding the line display_rotate=1
          • KirAsh4K Offline
            KirAsh4 Moderator
            The ‘DISPLAY=:0’ bit is simply telling the system (in this case the rpi), which monitor it should use, in this case, the attached one.
            For rotation, using ‘display_rotate’ you can tell the OS how to rotate the output:
            display_rotate=0           Normal
            display_rotate=1           90 degrees
            display_rotate=2          180 degrees
            display_rotate=3          270 degrees
            display_rotate=0x10000    horizontal flip
            display_rotate=0x20000    vertical flip
            • G Offline
              geeflaxx
              a little question:
              how i can delete my “desktop” and start with my npm (so i wanna after a restart direct to my npm not on my desktop)?
              • KirAsh4K Offline
                KirAsh4 Moderator
                You can’t. You need the desktop to run electron which is what displays the mirror. What you can do, is run an automatic (re)start of the mirror. For instructions, please visit https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                • G Offline
                  geeflaxx
                  thanks, but they don’t work
                  i create the script, and i saved it in the pm2
                  but if i restart my magic mirror they begin in the desktop
                  and if i use ‘pm2 start mm.sh’
                  they go to the mirror
                  with the command ‘pm2 show mm’ i see that is a x in the field “watch & reload”
                  what now ?
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    Then you didn’t do it correctly. Did you launch it, then save the task? You have to follow the steps one by one. Please go back and start from the top and do it again.
                    • G Offline
                      geeflaxx
                      http://www.bilder-upload.eu/show.php?file=e77336-1477512295.png
                      i only did it
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        There’s a glaring instruction right there on the screen that you did not follow. When you typed in pm2 startup it clearly told you what you need to do, which I don’t see anywhere in your command log. I’m sorry, but if you can’t follow directions given to you, there is really not a whole lot anyone can do to help you. The instructions are there for you to follow, please do that.
