Starting up MM via SSH don't work
Hello,
This is my first post here, so I would like to greet everyone!So I installed MM on my PI 3 v1.2 year 2015, and I tried to start it via SSH.
Of course I read manual and I’m trying to start it byDISPLAY=:0 npm start
But it’s giving me this error
root@raspberrypi:~/MagicMirror# DISPLAY=:0 npm start > magicmirror@2.4.1 start /root/MagicMirror > sh run-start.sh No protocol specified (electron:2352): Gtk-WARNING **: cannot open display: :0 npm ERR! Linux 4.14.70-v7+ npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" npm ERR! node v4.2.1 npm ERR! npm v2.14.7 npm ERR! code ELIFECYCLE npm ERR! magicmirror@2.4.1 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.4.1 start script 'sh run-start.sh'. npm ERR! This is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! sh run-start.sh npm ERR! You can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /root/MagicMirror/npm-debug.log
What is strange when I typed
echo $DISPLAY
on PI it showed value 0.0, so I also triedDISPLAY=:0.0 npm start
but the result is still the same…Some specs:
I’m using ssh via MacBook Pro Mid 2014, Mac OS High Sierra 10.13.6
Fresh install of Rasbian Stretch, kernel 4.14.70-v7+Please help :C
@grimorth said in Starting up MM via SSH don’t work:
npm ERR! npm v2.14.7You can certainly start by updating node, and thus, npm. It might even solve your issue.
@mykle1 Okay, that’s a good start, however I just messed up. I tried to update node, but it said that it’s already in the newest version (10.0) but as you pointed out npm shows 4.2.1, so I decided to completely remove node and install it again. I deleted some folders under
/usr/local/lib
and/usr/local/include
, however it’s still shows that node is installed. Can you help me get rid of it and reinstall? Also maybe reinstall of whole MM would be helpful?
@grimorth Update. I managed to get rid of all node versions and installed 10.0 but I can’t start npm now. It says
root@raspberrypi:~/MagicMirror# npm -v -su: /usr/local/bin/npm: No such file or directory
I tried
apt-get install npm
but without luck…
Update.
After reboot node and npm are up to date. However I still can’t start up MM via SSH. From PI terminal it works like a charm.root@raspberrypi:~/MagicMirror# DISPLAY=:0 npm start > magicmirror@2.4.1 start /root/MagicMirror > sh run-start.sh No protocol specified (electron:942): Gtk-WARNING **: cannot open display: :0 npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! magicmirror@2.4.1 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.4.1 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-09-23T00_09_27_111Z-debug.log root@raspberrypi:~/MagicMirror# DISPLAY=:0.0 npm start > magicmirror@2.4.1 start /root/MagicMirror > sh run-start.sh No protocol specified (electron:965): Gtk-WARNING **: cannot open display: :0.0 npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! magicmirror@2.4.1 start: `sh run-start.sh` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.4.1 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-09-23T00_09_42_728Z-debug.log
Error log:
root@raspberrypi:~/.npm/_logs# cat 2018-09-23T00_09_42_728Z-debug.log 0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ] 2 info using npm@6.4.1 3 info using node@v10.11.0 4 verbose run-script [ 'prestart', 'start', 'poststart' ] 5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1 6 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1 7 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true 8 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/root/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin 9 verbose lifecycle magicmirror@2.4.1~start: CWD: /root/MagicMirror 10 silly lifecycle magicmirror@2.4.1~start: Args: [ '-c', 'sh run-start.sh' ] 11 silly lifecycle magicmirror@2.4.1~start: Returned: code: 1 signal: null 12 info lifecycle magicmirror@2.4.1~start: Failed to exec start script 13 verbose stack Error: magicmirror@2.4.1 start: `sh run-start.sh` 13 verbose stack Exit status 1 13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16) 13 verbose stack at EventEmitter.emit (events.js:182:13) 13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14) 13 verbose stack at ChildProcess.emit (events.js:182:13) 13 verbose stack at maybeClose (internal/child_process.js:962:16) 13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5) 14 verbose pkgid magicmirror@2.4.1 15 verbose cwd /root/MagicMirror 16 verbose Linux 4.14.70-v7+ 17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" 18 verbose node v10.11.0 19 verbose npm v6.4.1 20 error code ELIFECYCLE 21 error errno 1 22 error magicmirror@2.4.1 start: `sh run-start.sh` 22 error Exit status 1 23 error Failed at the magicmirror@2.4.1 start script. 23 error This is probably not a problem with npm. There is likely additional logging output above. 24 verbose exit [ 1, true ]
Ok, now that your node and npm are up to date, I wouldn’t say reinstall MM just yet. Not until you’ve heard from a few others about your issue.
In the meantime, would you try
DISPLAY=:0 nohup npm start &
I think that sh does not like
and will not work
@Mykle1 I tried your solution earlier but result was still the same.
I also managed to fix everything
I reinstalled whole rasbian, because I really messed up and when I tried to star MM directly on PI, it was showing only black screen. Then I installed MM directly on PI.
Earlier I was installing it via SSH. Shouldn’t be the issue yet it was…
Now everything runs smooth, I can start MM directly and via SSH with both commandsDISPLAY=:0 nohup npm start &
andDISPLAY=:0 npm start
.Thanks for all support
Life is good. Enjoy!
