    Help with inserting a script into a <div> element
    11 Posts 5 Posters 3.4k Views 5 Watching
      AdamBD
      Hi!
      I am working to create a custom module for the moovit transit service. Moovit has an out-of-the-box widget, which is a simple div with a script in it. The issue I am having is that the widget they provide is something thats supposed to be placed in the HTML directly:
      <div class="mv-wtp" data-metro="1" data-lang="en" style="width:900px; height:900px;" data-from="hakerem+4+tel" data-to="sarona" >
        <script>(function(d, s, id) {
            let js, fjs = d.getElementsByTagName(s)[0];
            js = d.createElement(s); js.id = id;
            js.src = "https://widgets.moovit.com/wtp/en";
            fjs.parentNode.insertBefore(js, fjs);
        }(document, 'script', 'moovit-jsw'));
      </script>
      </div>
      I dont know how to get a script to run if I am creating a div element from the document object in the module, for example:
      getDom: function() {
        var element = document.createElement("div")
        element.className = "myContent"
        element.innerHTML = "Hello, World! "
        return element
      I understand that if you set innerHTML to be a script it will never evaluate in the browser.
      Anyone have suggestions on how to do this?
      ? justjim1220J 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @AdamBD
        @adambd
        There are several ways to insert script after loading. Here are examples;
        //insert before other scripts
        var tag = document.createElement("script")
        tag.src = "EXTERNAL_SCRIPT_URL"
        var firstScriptTag = document.getElementsByTagName("script")[0]
        firstScriptTag.parentNode.insertBefore(tag, firstScriptTag)
        //insert after other scripts
        var tag = document.createElement("script");
        tag.src = "EXTERNAL_SCRIPT_URL";
        document.getElementsByTagName("head")[0].appendChild(tag);
        Or, You can make a HTML file which contains the target widget, and load it with iFrame.
          AdamBD
          Hi Sean, thanks for answering!
          tag.src = “EXTERNAL_SCRIPT_URL”;
          What should this point to? A local file on my machine?
            sdetweil @AdamBD
            @adambd EXTERNAL url = “https://some_server_com/etc/whatever.js”
              AdamBD @sdetweil
              @sdetweil Hey sean, But then I need to have a ‘server’ running to pull this in. I would prefer just to keep it in another node file in the project. any thoughts on how to do that?
              ? S 2 Replies Last reply Reply Quote 0
              • ? Offline
                @adambd
                How about trying this?
                [card:eouia/MMM-Widget]
                Mykle1M justjim1220J 2 Replies Last reply Reply Quote 2
                  sdetweil @AdamBD
                  @adambd if you look at the MMM_ImagedPhotos and MMM_ImageSlideshow modules, you will see they map a url for the express server running in MM
                  	extraRoutes: function() {
                  		var self = this;
                  		this.expressApp.get("/MMM-ImagesPhotos/photos", function(req, res) {
                  			self.getPhotosImages(req, res);
                  		this.expressApp.use("/MMM-ImagesPhotos/photo", express.static(self.path_images));
                  	// return photos-images by response in JSON format.
                  	getPhotosImages: function(req, res) {
                  		directoryImages = this.path_images;
                  		var imagesPhotos = this.getImages(this.getFiles(directoryImages)).map(function (img) {
                  			return {url: "/MMM-ImagesPhotos/photo/" + img};
                  		res.send(imagesPhotos);
                  • justjim1220J Offline
                    justjim1220 Module Developer @AdamBD
                    @adambd
                    element.innerHTML =  `<div>     ENTER HTML CODE    </div>`
                    you have to have the ` before and after the div indicators
                    the key to the left of the 1 key
                    Jim Hallock - 1995
                      Mykle1 Project Sponsor Module Developer @Guest
                      @sean
                      You could not have made it any easier. Fantastic idea, sean!
                        justjim1220 Module Developer @Guest
                        @sean
                        The only problem with this widget module… It doesn’t allow clickable links to be clicked…
                        Otherwise, It’s pretty cool! :smiling_face_with_sunglasses:
                        Jim Hallock - 1995
                          Mykle1 Project Sponsor Module Developer @justjim1220
                          @justjim1220 said in Help with inserting a script into a <div> element:
                          Most people don’t use a mouse with their mirrors
