    MMM-earth
    8 Posts 4 Posters 3.3k Views 3 Watching
      StrIIker
      Hello,
      I wanted to load up this module but it does not appear to be working correctly. I get Hello, Mother Earth. (and a spinning icon). Can anyone confirm that this still works or has the source for the images been shut down? Thanks!
      • N Offline
        Nilnik Project Sponsor
        Hello! It’s working for me. My config:
                                disabled: false,
                                module: "MMM-EARTH",
                                position: "middle_center",
                                        mode: "Natural",
                                        rotateInterval: 15000,
                                        animationSpeed: 0,
                                        MaxWidth: "45%",
                                        MaxHeight: "45%",
          StrIIker @Nilnik
          @nilnik
          Hmm, thank you for the response. I wonder what’s the issue then…
          This is my config for the two modules being discussed… (I also tested adding the disabled: no but that had no effect…)
              module: 'MMM-MARS',
              position: 'bottom_left',
                  rover: "curiosity",              // which rover? curiosity, opportunity or spirit
                  sol: "200",                      // sol date you want pictures from
                  useHeader: false,                // true if you want a header
                  header: "",                      // useHeader must be true
                  maxWidth: "300px",
                  rotateInterval: 5 * 60 * 1000,   // new image 5 minutes
              position: "bottom_center",
                  mode: "Natural",
                  MaxWidth: "50%",
                  MaxHeight: "50%",
          justjim1220J 1 Reply Last reply Reply Quote 0
          • justjim1220J Offline
            justjim1220 Module Developer @StrIIker
            @striiker
            Try rebooting your system
            I have found that sometimes that is what it takes to get some modules to work after first install, and load and not working.
            Jim Hallock - 1995
              StrIIker @justjim1220
              @justjim1220 said in MMM-earth:
              @striiker
              Yeah, this solved it. Thanks again! Rebooting was always my goto with Microsoft stuff but I got spoiled with Linux…
                bhepler Module Developer @StrIIker
                @striiker - In the future, you may be able to get away with merely restarting the MagicMirror process. If you’re using pm2 with a default installation, it’s just pm2 restart MagicMirror.
                justjim1220J S 2 Replies Last reply Reply Quote 0
                  justjim1220 Module Developer @bhepler
                  @bhepler
                  I’ve tried the reload/restart of MagicMirror. It doesn’t always work. I have been finding since this last update, that most of the time it requires a restart of the system.
                  Jim Hallock - 1995
                    StrIIker @bhepler
                    @bhepler said in MMM-earth:
                    Hi! Thank you for the suggestion however I have a cron job which restarts MagicMirror every 5 hours. I do this because of the persistent issue of having something in Magic Mirror crashing, causing it to stop refreshing and leaving me at a black screen. The only way to solve it is to manually reload or restart Magic Mirror. So, while I was experiencing this issue, the system had restarted MagicMirror several times. As mentioned by @justjim1220 , the solution was to reboot.
