    Synology-Docker-Magicmirror
    22 Posts 3 Posters 13.3k Views 3 Watching
    • O Offline
      OceanK
      Hey!
      I have synology NAS. I would like to run Magic Mirror in docker container. I have some hard time to follow the guide for it.
      could someone tell me step by step what do do? and how do I configure the folder path for installation in the docker for magicmirror.
      best regards Kim
      • C Offline
        cyberphox
        Looking for the same…i understand how to search the docker registry to find the image…but unsure after that!
        • O Offline
          OceanK
          yeah I have installed the image but then when Im trying to configure the folder path, thats when I dont know what to do?
          please anyone can help us?
          C 2 Replies Last reply Reply Quote 1
          • C Offline
            cyberphox @OceanK
            @oceank I’m exactly at the same step! hope a guru comes along!!
            • C Offline
              cyberphox @OceanK
              @oceank got it running if you need some help!
              • O Offline
                OceanK @cyberphox
                @cyberphox wow! cool, how?
                • C Offline
                  cyberphox
                  some primary info here:
                  https://forum.magicmirror.builders/topic/9120/synology-docker-tutorial/2
                  • O Offline
                    OceanK @cyberphox
                    @cyberphox thanx mate:
                    what about your last part?
                    just need to figure out how to enter the command in shell for it to run
                    after configuring the module in docker , It will autostart as soon as I hit the done button?
                    • C Offline
                      cyberphox @OceanK
                      @oceank i didnt need to enter any commands as it was all done during the setup of the docker container when mapping the drives and port
                      O T 2 Replies Last reply Reply Quote 0
                      • O Offline
                        OceanK @cyberphox
                        @cyberphox thanx mate!
                        its working , YES!
                        • C Offline
                          cyberphox
                          im sure the performance is better than running on a Pi
                          • O Offline
                            OceanK @cyberphox
                            @cyberphox hey again!
                            how would this work.
                            the module mmm-voice? so im running mm in docker on synology. I config the file etc.
                            how would I setup the raspberry pi to act as a client, and the pi need to have the mic and speakers etc.
                            because I cannot connect mic and etc to the synology server to pic up the voice…thats all raspberry pi job.
                            • C Offline
                              cyberphox
                              Was wondering the same thing as I have run some voice stuff on my ubuntu laptop setup…
                              Not sure how it can or would work!
                              • T Offline
                                turuncuoglu @cyberphox
                                @cyberphox I know it is little old but I need some help. I run the docker. It looks like it is starting from the log files. It is looking for config files and uses the default one. But when point the browser to 192.168.xx.xx:8080 nothing happens. What else I need to do? Thanks
                                • C Offline
                                  cyberphox
                                  Are you able to edit your config file? Might be a whitelist issue.
                                  I know i was having trouble on how to define where my config file and module folder were but figured it out
                                  • T Offline
                                    @cyberphox I know how to get to the config file from synology but I don’t know what I should make it to. Is there one that I should start with?
                                    • T Offline
                                      turuncuoglu
                                      @cyberphox Thaks for the tip. I got it working now. One more question. How do you install new modules?
                                      • C Offline
                                        cyberphox @turuncuoglu
                                        @turuncuoglu i used putty on my windows machine to ssh in and run the commands from there
                                        • T Offline
                                          turuncuoglu
                                          @cyberphox thanks. I found out you can also run it from the container.
                                          • C Offline
                                            @turuncuoglu now if there was a way to run Voice commands from it…
