    Darksky weather module not loading
    18 Posts 5 Posters 8.8k Views 4 Watching
    • K Offline
      Kaviish @Mykle1
      @mykle1 I did follow what the readme said but still it isn’t loading
        AxLed Module Developer
        @Kaviish
        It looks that there is a comma to much.
        Try
        longitude: 72.8777
        instead of
        longitude: 72.8777,
        AxLED
        • K Offline
          Kaviish @AxLed
          @axled still not working. Opened console this is wat i got. 0_1540729568319_Screenshot 2018-10-28 at 5.55.24 PM.png
            Mykle1 Project Sponsor Module Developer @Kaviish
            @kaviish
            Looking at that error message it appears your latitude is 149.076. That will break the module. Clear the latitude line of your config entry and re=enter.
            • K Offline
              Kaviish
              What does that mean the latitude on my config file is 19.0760
                @kaviish said in Darksky weather module not loading:
                Not according to the console error message you posted.
                  buzzman
                  @Kaviish
                  here is mine lat and long . you need the ’ at the start and at the end of the number .it works great
                  ‘43.xxxx’,
                  ‘-88.xxxx’
                    Mykle1 Project Sponsor Module Developer @buzzman
                    @buzzman said in Darksky weather module not loading:
                    No sir, you do not need the quotes, nor are they called for in the readme. However, it does work with the quotes but that is not his issue at this point.
                    • K Offline
                      Kaviish @Mykle1
                      @mykle1 so should I delete the module and download it again?
                      • K Offline
                        Kaviish
                        then can yall suggest me some weather module other than this?
