    MagicMirror on Windows 10
    2 Posts 2 Posters 5.1k Views 3 Watching
    • C Offline
      cpramhofer
      Re: Developers running Windows 10.
      Hi Guys (@KirAsh4, @arek123 ) is there anyone out there who had a short setup guide to make MagicMirror run on a Raspberry 3 with Windows 10 IOT on it?
      As there are some problems with electron maybe windows with edge could be a solution!
      • cowboysdudeC Offline
        cowboysdude Module Developer
        Open explorer
        create a new folder called magicmirror
        download magicmirror and unpack it in that dir
        Open a CMD window and go to the magicmirror directory
        Go to Node js and get node and install it…
        Once you have that installed go back to your CMD window and type in
        “npm install”
        If everything is in correctly it should install the magicmirror software
        Once that’s installed type “npm start”… should start the mirror…
        I don’t think I missed anything but if I did someone please feel free to point it out!
