Navigation
    • Search
    Absolute date
    Troubleshooting
    4146
    • D
      deadherring last edited by
      I am trying to get the calendar module display my calendar in absolute date. I want appointments to read the actual time of the appointment, e.g. “3PM”
      This is what my MM is doing:
      Appointment today: in an hour
      Appointment tomorrow: Tomorrow at 11 AM
      Appointment 2 days from now: Tuesday at 12PM
      Appointment 4 days from now: In 4 days
      Here’s the calendar part of my config.js: (apologies, I know I’m supposed to post this in markdown but am not sure how)
      module: ‘calendar’,
      header: ‘Calendar’,
      position: ‘top_left’,
      symbol: 'calendar-check-o ',
      url: ‘redacted’,
      symbol: ‘rocket’,
      url: ‘redacted’
      Here’s what the top part of my calendar.js file looks like:
      Module.register(“calendar”,{
      // Define module defaults
      defaults: {
      	maximumEntries: 10, // Total Maximum Entries
      	maximumNumberOfDays: 365,
      	displaySymbol: true,
      	defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
      	displayRepeatingCountTitle: false,
      	defaultRepeatingCountTitle: '',
      	maxTitleLength: 15,
      	fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
      	animationSpeed: 2000,
      	fade: false,
      	urgency: 7,
      	timeFormat: "absolute",
      	fadePoint: 0.25, // Start on 1/4th of the list.
      			symbol: "calendar",
      			url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics",
      	titleReplace: {
      		"De verjaardag van ": "",
      		"'s birthday": ""
      Any help is appreciated.
      Nathan
      • D
        deadherring @deadherring last edited by
        Anyone? Does anyone have absolute date working as I describe? Can someone post the relevant portion of their config file so I can see what you’ve done?
        Thanks.
        • M
          mjtice last edited by
          Any word on this? I’m using a 7" raspberry pi display and that ‘Tomorrow at 10:00 AM’ eats up a lot of real estate.
          Here’s my config:
                              module: 'calendar',
                              header: 'My Calendar',
                              position: 'top_right',
                                    url: '[redacted]'
                                maximumEntries: 10,
                                maxTitleLength: 12,
                                titleReplace: {'Appointment':'Appt'},
                                displaySymbol: false,
                                timeFormat: 'relative'
          • M
            … and by
            timeFormat: ‘relative’
            I mean
            timeFormat: ‘absolute’
            ugh.
            • M
              This post is deleted!
              • M
                Turns out my problem came down mostly to not really understanding the difference between ‘absolute’ and ‘relative’… I fixed my problem by modifying the code in calendar.js slightly.
                 // Otherwise just say 'Today/Tomorrow at such-n-such time'
                 timeWrapper.innerHTML = moment(event.startDate, "x").calendar(null, {
        sameDay: 'H:mm',
        nextDay: '[Tomorrow] H:mm',
        nextWeek: 'dddd',
        lastDay: '[Yesterday]',
        lastWeek: '[Last] dddd',
        sameElse: 'DD/MM/YYYY'
                I sort of hijacked this thread. Sorry (but I think my solution might help out the OP ).
                D D 2 Replies Last reply Reply Quote 0
                • D
                  daikaiju @mjtice last edited by
                  @mjtice What lines did you implement that code on?
                  • D
                    DeanoAus @mjtice last edited by
                    @mjtice Thanks man, that solved my problem too. Except I added NextWeek: ‘dddd DD/MM/YYYY’
                    Cheers!
                    • M
                      mjtice @daikaiju last edited by
                      @daikaiju it’s on line 245 in the current release. Keep in mind that if you upgrade you’ll lose those changes (as I did exactly 2 days after I made that post…).
