    Are you saying "UNICORN"? Error ... please help me !
    10 Posts 3 Posters 2.2k Views 3 Watching
    • H
      HeyZealot
      Hello I am not good at English.
      English is being used by Google Translator.
      When I was using SMARTMIRROR, suddenly it did not answer my voice, but popup “Are you saying” Unicorn “?” There is no response after popup.
      How do I fix it? please help me T_T
        A Former User @HeyZealot
        @heyzealot
        I think you’re using my module MMM-AssistantMk2(maybe old version), but incomplete configuration. Just remove transcriptionHook from your configuration. It was just sample value.
        • H
          HeyZealot
          This post is deleted!
          • H
            HeyZealot @Guest
            @sean how can i use your past version ?
              @heyzealot
              Why do you want the old version? newer is more stable.
              Anyway, I cannot remember which version I had put the sameple value “Unicorn” blah blah…
              Tell me which version are you using? you can see it from package.json.
              • H
                HeyZealot @Guest
                @sean i used 2.1.0 version. i want use 2.0 version…
                can i use it ? T_T
                ? 1 Reply Last reply Reply Quote -1
                  @heyzealot
                  If you already installed,
                  cd ~/MagicMirror/modules/MMM-AssistantMk2
                  git pull
                  git branch 2.0.0
                  git checkout  # I think this is not needed,
                  would be.
                  Or,
                  git pull
                  git checkout 2.0.0
                  And you can see the manual or any other files of 2.0.0 in Github by select Branch: button as 2.0.0.
                  H lavolp3L 2 Replies Last reply Reply Quote 0
                  • H
                    HeyZealot @Guest
                    @sean thanks! i will try.
                    • lavolp3L
                      lavolp3 Module Developer @Guest
                      @sean as far as I understand this will create a local branch and that’s it.
                      he will need to track pull the branch 2.0.0 doesn’t he? So for example
                      git branch -f 2.0.0 origin/2.0.0 //create branch 2.0.0 and track origin/2.0.0
                      git checkout 2.0.0
                      git pull
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                        A Former User @lavolp3
                        @lavolp3
                        You may be right. I had some confusing with my environment. Thanks.
