    MMM-synology-ds
    6 Posts 6 Posters 5.9k Views 7 Watching
    • T Offline
      Thlb0
      Hi
      Another module that I did for my own needs, maybe it’ll be useful for you to.
      This module display the current tasks of your Synology Download Station
      Screenshots available on github readme.
      [card:Thlb/MMM-synology-ds]
      • C Offline
        Cato Module Developer
        Cool! Now I want a DS just to have that module… 😀
        • Y Offline
          yawns Moderator
          Looks Nice. I’m curious if this will work with qnap nas as well, maybe with some tweaks
          • P Offline
            plumcraft
            I got this error when i launch the Magic Mirror :
            Loading module helpers ...
            App threw an error during load
            Error: /home/plumcraft/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEi
                at Error (native)
                at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:178:20)
                at Object.Module._extensions..node (module.js:583:18)
                at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:178:20)
                at Module.load (module.js:473:32)
                at tryModuleLoad (module.js:432:12)
                at Function.Module._load (module.js:424:3)
                at Module.require (module.js:483:17)
                at require (internal/module.js:20:19)
                at Object.<anonymous> (/home/plumcraft/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/lib/index.js:3:13)
                at Error (native)
            npm dependencies are installed, here is my config file :
            module: ‘MMM-synology-ds’,
            position: ‘left_bottom’,
            header: ‘Download Station’,
            host: ‘xxxxxxx’,
            port: ‘5000’, // Server port (not required if default port (5000) is used)
            login: ‘xxxxxxx’,
            passwd: ‘xxxxxxx’,
            refreshInterval: 10, // in seconds
            compactMode: true, // recommanded in left or right position.
              shashank @Thlb0
              @Thlb0
              Hi, i am getting this below error
              • F Offline
                fox
                Could be a cool module
