    Need help in Javascript for resetting module if user no longer interacts after x seconds.
    3 Posts 3 Posters 1.1k Views 3 Watching
      jchariot
      I am using a Sonar module on Raspberry Pi to indicate whether someone is in front of the mirror or not. I use MMM-websocket to transfer this information to MagicMirror and it works correctly. Now, when there is nobody in front of the mirror for x seconds, I would like to call a function to reset the module. However, I got an issue on Javascript side:
      Currently I have this function for resetting in my module:
      userNoLongerInFrontSoReset: function(){
          if (this.resetTimeout != null){
              clearTimeout(this.resetTimeout);
          this.resetTimeout = setTimeout(function(){
              console.log("resetTimeout setTimeout");
              this.myVar = null;
              this.myVar2 = null;
              this.myVar3 = null;
              this.sendNotification("PAGE_CHANGED", 0);
              this.updateDom();
          }, 3000)
      I see from the console that resetTimeout setTimeout is being printed out from the code above, but then it got:
      Uncaught TypeError: this.sendNotification is not a function at myOwnModule.js:xxx
      So this is the problem. All those variables myVar, etc. are not being referred correctly as well as the function sendNotification. How can I set all myVar and call sendNotification from the anonymous function in this case? Or is there a better way to do this?
      Thank you,
      • ? Offline
        A Former User @jchariot
        @jchariot
        Change this;
          this.updateDom();
        to this;
        this.resetTimeout = setTimeout(()=>{
          this.updateDom();
        Or this;
        var module = this
          module.sendNotification("PAGE_CHANGED", 0);
          module.updateDom();
        Inside of function(){...}, this will be function itself, so you cannot access this - referer to module - of upper level.
        To avoid, you can use ES6 style anonymous function ()=>{} instead function(){} or assign prior this to another temporal object.
        strawberry 3.141S 1 Reply Last reply Reply Quote 3
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Guest
          @sean or
            this.updateDom();
          }.bind(this));
