    Start or not...?
    44 Posts 4 Posters 36.7k Views 4 Watching
    • P Offline
      Peter
      @Egnos: I think you should just start!
      MM is a very funny project!
      Buy a Raspberry Pi, SD card, find an old monitor, keyboard and mouse and go!
      Burn an image on the SD card and try to get MM running.
      You don’t need all the other stuff (you can add it later).
      And I will give you some advice: after MM is working, save the config.js file (I saved it on a USB stick).
      Then try to add or change a module; is it working: fine!
      Is it not working: you still have the working config.js on the USB!
      About the Sonoff: you do not need a RPI or MM to maken the Sonoff working.
      The Sonoff is hardwired with the gardenlights; it has 1 IP adress with 4 channels.
      You can use your cellphone or a 433 Mhz remote to switch the channels.
      But I find it more fun to say: “Hey Google, turn on the fountain …”
      Another advice: read, read, read, search, read and finally: ask here …
      Peter
      • E Offline
        Egnos @Peter
        @peter thanks for your precious advice!
        I would like to start but for work I am often around Europe and time is always a little … !!
        I’ll start soon … promised!:smiling_face_with_halo:
        @peter said in Start or not...?:
        Ok, but how do you connect a sentence to GA with a command to Sonoff?
        Thanks for your patience!
        • P Offline
          Peter
          You have to make GA (on your cellphone) look for smart things.
          Sonoff has an app (eWelink) but there are a lot of smart switches, thermostats and other.
          After connecting the Sonoff with the app, it was recognized by GA.
          But again: you do not need a MM to make smart things work.
          Google home works even better; but building it yourself is a great part of the fun.
          I started my MM project about a year ago and it took me a lot of time to make it the way I liked.
          Now I am building a second one for my daughter and it takes me much less time.
          But it is really a lot of fun to make your own personalized project.
          Just try it!
          Good luck!
          Peter
            j.e.f.f Project Sponsor Module Developer @Egnos
            @egnos It’s free to subscribe to receive notifications from apps or services that broadcast via PubNub. Likely there is a cost associated if you want to send notifications through PubNub, but I don’t know what that cost is.
            • P Offline
              Peter
              @Egnos: one last advice: start with a Raspberry Pi 2B or 3B (not a zero or a 3B+).
              I have 5 RPI’s (bought them all secondhand).
              A lot of people buy a RPI and don’t know what to do with it.
              Peter
              • E Offline
                Egnos
                Sorry guys,
                exist a wireless sensor (WiFi, bluetooth,etc…) that transmits the temperature to the Raspberry?
                Maybe there is some MM module that manages the communication …
                Good night! :sleeping_face:
                  @egnos said in Start or not...?:
                  Pi 3B has WiFi and bluetooth built-in. Pi 2B needs a USB dongle, but they’re not expensive.
                  If you want to display your house temperature, you need a smart thermostat like a Nest or an Ecobee. There exists a module for Nest, but I don’t know about Ecobee. Maybe you would relay that through Home Assistant?
                  If you want to display the weather outside, there are a bunch of weather modules available. I’m sure will suit your needs well.
                  • P Offline
                    Peter
                    I use cheap Xiaomi sensors in all rooms in my house, displayed on MM.
                    Peter
                    • E Offline
                      Egnos @j.e.f.f
                      @j-e-f-f said in Start or not...?:
                      Yes, I have Raspberry PI3.
                      I would like to display the “real” outdoor temperature, if possible using a temperature sensor.
                      I would like the real external and internal temperature (the internal one I will take from a smart thermostat) always be visible on my MM.
                      The temperatures acquired by the various modules are estimates…correct?
                      Peter
                      Which module for MM do you use?
                      Which xiaomi sensor do you use?
                      I have another questions:
                      • I bought the “Sonoff 4ch pro r2” but I do not understand how to make the Sonoff work together with the physical switch.
                        Example:
                        STEP 1: I turn on the light 1 with Sonoff
                        STEP 2: I turn off the light 1 from the physical switch
                        STEP 3: I turn on the light 1 with Sonoff
                        It’s possible?
                      • Is it possible to receive feedback from the “Sonoff”?
                        Example: I would like to know if the house gate is open or closed or if the garden light is on, etc …
                      • the “Sonoff 4ch pro r2” has a 433Mhz receiver (I think it is used to open the automatic gates …) and I would like to use it using a 433Mhz transmitter.
                        Are there transmitters with 433Mhz for Raspberry?
                        Have you tested someone?
                        Could I use GA to open the gate at home?
                      Thank you for your precious help!!
                      • E Offline
                        Egnos
                        Hello everyone and happy new year!
                        I returned the “Sonoff 4ch pro r2” because it was not for me!
                        During the Christmas holidays I started the installation of the Magic Mirror with all its modules.
                        These days I’m trying to install the module MMM-Assistantmk2 but I did not understand how to activate the assistant with my voice.
                        In the configuration of MMM-Assistantmk2 module I did not find a way to insert a watchword to wake up the Assistant.
                        Can you help me?
                        Do you need to install modules like “MMM-Hotword” and “MMM-NotificationTrigger”?
                        Thanks guys.
                        • 3 / 5
