    Start or not...?
    44 Posts 4 Posters 34.8k Views 4 Watching
    • ? Offline
      A Former User @Egnos
      @egnos
      MMM-Hotword is needed if you want to activate it with voice hotword.
      • E Offline
        Egnos @Guest
        @sean said in Start or not...?:
        @egnos
        Thanks Sean!
        So if I only install the module “MMM-assistantmk2” how can I use it?
        So if I only install the module “MMM-assistantmk2” I can not do anything … correct?
        • ? Offline
          @egnos
          You can activate it with touching or clicking icon (If you have a touchable/clickable input method like touchscreen or mouse).
          Or You might have another input method like H/W button, or anything else. You can activate with other module which can emit notification. (Yes, Even default calendar module can activate this)
          I wanted to make this universal.
          • E Offline
            Egnos
            How can I activate it with the H / W keys?
            Only for test…
            This function be done directly with “MMM-assistantmk2” or should I always install “MMM-Hotword”?
            • ? Offline
              @egnos function itself is included. But activating that function with hotword needs MMM-Hotword.
              • E Offline
                Egnos
                Ok, so I have to install MMM-Hotword.
                • E Offline
                  Egnos
                  @sean I have some question on MMM-assistantmk2, MMM-Hotword and MMM-pages (or another module that creates multiple pages recommended by you…).
                  • MMM-assistantmk2: this module also speak Italian?
                  • MMM-Hotword: can I also use hot words in Italian?
                    Or can I use only the English hot words shown in the configuration file?
                  customizable notification trigger
                      notifications: {
                        PAUSE: "HOTWORD_PAUSE",
                        RESUME: "HOTWORD_RESUME",
                        LISTENING : "HOTWORD_LISTENING",
                        SLEEPING : "HOTWORD_SLEEPING",
                        ERROR : "HOTWORD_ERROR",
                  • MMM-pages (we accept advice…:winking_face: ): It is possible, through MMM-assistantmk2 or MMM-Hotword, to change page maybe saying: “Magic Mirror surveillance page or Magic Mirror multimedia page …”?
                    If yes, how?
                  Thanks.
                  • ? Offline
                    @egnos
                    If you set your profile to it-IT, it would.
                    MMM-Hotword(snowboy) can’t understand the language itself. It just will match the pattern of your voice with defined models. So, that is not configurable. However you can create your custom private hotword model(.pmdl) and use it. See the Snowboy website. (http://kitt.ai)
                    MMM-pages (we accept advice…😉 ): It is possible, through MMM-assistantmk2 or MMM-Hotword, to change page maybe saying: “Magic Mirror surveillance page or Magic Mirror multimedia page …”?
                    First; You have to make gAction or transcriptionHook . Here is a sample for transcriptionHook
                    transcriptionHook: {
                      "MY_HOOK_FOR_PAGE_2": {
                        pattern: "change to page 2",
                        command: "PAGE_2",
                    Then, you need to make a command to change page like this;
                    command: {
                      "PAGE_2" : {
                        notificationExec: {
                          notification: "PAGE_CHANGED",
                          payload: 2,
                    This is just sample, not tested. Read the instruction documents in repository.
                    • E Offline
                      Egnos @Guest
                      Ok, so I can substitute the words in English with those in Italian, changing in this way:
                          notifications: {
                            PAUSE: "HOTWORD_PAUSA",
                            RESUME: "HOTWORD_RIPRENDI",
                            LISTENING : "HOTWORD_ASCOLTA",
                            SLEEPING : "HOTWORD_DORMI",
                            ERROR : "HOTWORD_ERRORE",
                      What is the difference between gAction and transcriptionHook?
                      The code you wrote should be put under the module MMM-assistantmk2, MMM-Hotword or MMM-pages?
                      Is the MMM-pages module suitable for my needs or another module is better?
                      Thanks and sorry for the 1000 questions!!!
                      • ? Offline
                        @egnos
                        notifications: {
                        PAUSE: “HOTWORD_PAUSA”,
                        RESUME: “HOTWORD_RIPRENDI”,
                        LISTENING : “HOTWORD_ASCOLTA”,
                        SLEEPING : “HOTWORD_DORMI”,
                        ERROR : “HOTWORD_ERRORE”,
                        No, you SHOULD NOT do that modification. Those values are used for system communication between modules. Those are not related with user language or user experience. If you are not developer, you don’t need to touch them.
                        gAction is small application or conversation set on Assistant. It is harder to create, but give natural experience to user.
                        transcriptionHook is just little trick to catch some pattern from your vocal query when you order to Assistant. If some pattern be found when you say something, my module will execute defined command instead original response of Assistant. It’s easier to handle (comparing with gAction)
                        MMM-AssistantMk2. Read the instruction on github repository. (CONFIGURATION and USAGE documents)
                        • 4 / 5
