    Start or not...?
    44 Posts 4 Posters 37.7k Views 4 Watching
    • E Offline
      Egnos @Peter
      @peter thanks for your precious advice!
      I would like to start but for work I am often around Europe and time is always a little … !!
      I’ll start soon … promised!:smiling_face_with_halo:
      @peter said in Start or not...?:
      But I find it more fun to say: “Hey Google, turn on the fountain …”
      Ok, but how do you connect a sentence to GA with a command to Sonoff?
      Thanks for your patience!
        Peter
        You have to make GA (on your cellphone) look for smart things.
        Sonoff has an app (eWelink) but there are a lot of smart switches, thermostats and other.
        After connecting the Sonoff with the app, it was recognized by GA.
        But again: you do not need a MM to make smart things work.
        Google home works even better; but building it yourself is a great part of the fun.
        I started my MM project about a year ago and it took me a lot of time to make it the way I liked.
        Now I am building a second one for my daughter and it takes me much less time.
        But it is really a lot of fun to make your own personalized project.
        Just try it!
        Good luck!
        Peter
          j.e.f.f Project Sponsor Module Developer @Egnos
          @egnos It’s free to subscribe to receive notifications from apps or services that broadcast via PubNub. Likely there is a cost associated if you want to send notifications through PubNub, but I don’t know what that cost is.
            Peter
            @Egnos: one last advice: start with a Raspberry Pi 2B or 3B (not a zero or a 3B+).
            I have 5 RPI’s (bought them all secondhand).
            A lot of people buy a RPI and don’t know what to do with it.
            Peter
            • E Offline
              Egnos
              Sorry guys,
              exist a wireless sensor (WiFi, bluetooth,etc…) that transmits the temperature to the Raspberry?
              Maybe there is some MM module that manages the communication …
              Good night! :sleeping_face:
                @egnos said in Start or not...?:
                Pi 3B has WiFi and bluetooth built-in. Pi 2B needs a USB dongle, but they’re not expensive.
                If you want to display your house temperature, you need a smart thermostat like a Nest or an Ecobee. There exists a module for Nest, but I don’t know about Ecobee. Maybe you would relay that through Home Assistant?
                If you want to display the weather outside, there are a bunch of weather modules available. I’m sure will suit your needs well.
                  Peter
                  I use cheap Xiaomi sensors in all rooms in my house, displayed on MM.
                  Peter
                  • E Offline
                    Egnos @j.e.f.f
                    @j-e-f-f said in Start or not...?:
                    Yes, I have Raspberry PI3.
                    I would like to display the “real” outdoor temperature, if possible using a temperature sensor.
                    I would like the real external and internal temperature (the internal one I will take from a smart thermostat) always be visible on my MM.
                    The temperatures acquired by the various modules are estimates…correct?
                    Peter
                    Which module for MM do you use?
                    Which xiaomi sensor do you use?
                    I have another questions:
                    • I bought the “Sonoff 4ch pro r2” but I do not understand how to make the Sonoff work together with the physical switch.
                      Example:
                      STEP 1: I turn on the light 1 with Sonoff
                      STEP 2: I turn off the light 1 from the physical switch
                      STEP 3: I turn on the light 1 with Sonoff
                      It’s possible?
                    • Is it possible to receive feedback from the “Sonoff”?
                      Example: I would like to know if the house gate is open or closed or if the garden light is on, etc …
                    • the “Sonoff 4ch pro r2” has a 433Mhz receiver (I think it is used to open the automatic gates …) and I would like to use it using a 433Mhz transmitter.
                      Are there transmitters with 433Mhz for Raspberry?
                      Have you tested someone?
                      Could I use GA to open the gate at home?
                    Thank you for your precious help!!
                    • E Offline
                      Egnos
                      Hello everyone and happy new year!
                      I returned the “Sonoff 4ch pro r2” because it was not for me!
                      During the Christmas holidays I started the installation of the Magic Mirror with all its modules.
                      These days I’m trying to install the module MMM-Assistantmk2 but I did not understand how to activate the assistant with my voice.
                      In the configuration of MMM-Assistantmk2 module I did not find a way to insert a watchword to wake up the Assistant.
                      Can you help me?
                      Do you need to install modules like “MMM-Hotword” and “MMM-NotificationTrigger”?
                      Thanks guys.
                        A Former User @Egnos
                        @egnos
                        MMM-Hotword is needed if you want to activate it with voice hotword.
                        • E Offline
                          Egnos @Guest
                          @sean said in Start or not...?:
                          @egnos
                          Thanks Sean!
                          So if I only install the module “MMM-assistantmk2” how can I use it?
                          So if I only install the module “MMM-assistantmk2” I can not do anything … correct?
                            @egnos
                            You can activate it with touching or clicking icon (If you have a touchable/clickable input method like touchscreen or mouse).
                            Or You might have another input method like H/W button, or anything else. You can activate with other module which can emit notification. (Yes, Even default calendar module can activate this)
                            I wanted to make this universal.
                            • E Offline
                              Egnos
                              How can I activate it with the H / W keys?
                              Only for test…
                              This function be done directly with “MMM-assistantmk2” or should I always install “MMM-Hotword”?
                                @egnos function itself is included. But activating that function with hotword needs MMM-Hotword.
                                • E Offline
                                  Egnos
                                  Ok, so I have to install MMM-Hotword.
                                  • E Offline
                                    Egnos
                                    @sean I have some question on MMM-assistantmk2, MMM-Hotword and MMM-pages (or another module that creates multiple pages recommended by you…).
                                    • MMM-assistantmk2: this module also speak Italian?
                                    • MMM-Hotword: can I also use hot words in Italian?
                                      Or can I use only the English hot words shown in the configuration file?
                                    customizable notification trigger
                                        notifications: {
                                          PAUSE: "HOTWORD_PAUSE",
                                          RESUME: "HOTWORD_RESUME",
                                          LISTENING : "HOTWORD_LISTENING",
                                          SLEEPING : "HOTWORD_SLEEPING",
                                          ERROR : "HOTWORD_ERROR",
                                    • MMM-pages (we accept advice…:winking_face: ): It is possible, through MMM-assistantmk2 or MMM-Hotword, to change page maybe saying: “Magic Mirror surveillance page or Magic Mirror multimedia page …”?
                                      If yes, how?
                                    Thanks.
                                      @egnos
                                      If you set your profile to it-IT, it would.
                                      MMM-Hotword(snowboy) can’t understand the language itself. It just will match the pattern of your voice with defined models. So, that is not configurable. However you can create your custom private hotword model(.pmdl) and use it. See the Snowboy website. (http://kitt.ai)
                                      MMM-pages (we accept advice…😉 ): It is possible, through MMM-assistantmk2 or MMM-Hotword, to change page maybe saying: “Magic Mirror surveillance page or Magic Mirror multimedia page …”?
                                      First; You have to make gAction or transcriptionHook . Here is a sample for transcriptionHook
                                      transcriptionHook: {
                                        "MY_HOOK_FOR_PAGE_2": {
                                          pattern: "change to page 2",
                                          command: "PAGE_2",
                                      Then, you need to make a command to change page like this;
                                      command: {
                                        "PAGE_2" : {
                                          notificationExec: {
                                            notification: "PAGE_CHANGED",
                                            payload: 2,
                                      This is just sample, not tested. Read the instruction documents in repository.
                                      • E Offline
                                        Egnos @Guest
                                        Ok, so I can substitute the words in English with those in Italian, changing in this way:
                                            notifications: {
                                              PAUSE: "HOTWORD_PAUSA",
                                              RESUME: "HOTWORD_RIPRENDI",
                                              LISTENING : "HOTWORD_ASCOLTA",
                                              SLEEPING : "HOTWORD_DORMI",
                                              ERROR : "HOTWORD_ERRORE",
                                        What is the difference between gAction and transcriptionHook?
                                        The code you wrote should be put under the module MMM-assistantmk2, MMM-Hotword or MMM-pages?
                                        Is the MMM-pages module suitable for my needs or another module is better?
                                        Thanks and sorry for the 1000 questions!!!
                                          @egnos
                                          notifications: {
                                          PAUSE: “HOTWORD_PAUSA”,
                                          RESUME: “HOTWORD_RIPRENDI”,
                                          LISTENING : “HOTWORD_ASCOLTA”,
                                          SLEEPING : “HOTWORD_DORMI”,
                                          ERROR : “HOTWORD_ERRORE”,
                                          No, you SHOULD NOT do that modification. Those values are used for system communication between modules. Those are not related with user language or user experience. If you are not developer, you don’t need to touch them.
                                          gAction is small application or conversation set on Assistant. It is harder to create, but give natural experience to user.
                                          transcriptionHook is just little trick to catch some pattern from your vocal query when you order to Assistant. If some pattern be found when you say something, my module will execute defined command instead original response of Assistant. It’s easier to handle (comparing with gAction)
                                          MMM-AssistantMk2. Read the instruction on github repository. (CONFIGURATION and USAGE documents)
                                          • E Offline
                                            Egnos
                                            Sorry guys i need your help again!
                                            I had to reinstall raspbian due to a module that did not work.
                                            Before formatting the SD, I backed up the MagicMirror folder.
                                            Question: can I copy the folders with the old modules (Mmm-assistantmk2, MMM-Pages, etc…) in the new MagicMirror installation?
                                            Thanks.
                                            • 2 / 3
