    Start or not...?
    44 Posts 4 Posters 41.7k Views 4 Watching
      Peter
      Turning on the gardenlights and the fountain is done with a Sonoff 4ch pro.
      A cheap smart switch.
      You can add all kinds of smart stuff to GA (Philips hue, Ikea,etc).
      Second question; I think you do not need the Google AIY, but I experienced it to be very easy to setup.
      And I bought it very cheap secondhand …
      But it is possible to build it yourself (google is your friend).
      Peter
      E 2 Replies Last reply Reply Quote 0
        A Former User
        As a private-hobby developer, I don’t want to talk about my things by myself. So still yet I haven’t.
        But MMM-AssistantMk2 has what you want as its feature.
        • embedded GA(Google Assistant SDK for device) fully integrated in MM with nodejs.
        • custom commands available by transcription hooking, IFTTT and google Action for assistant.
        • it could control RPI, MM and modules by sending notification, executing external shell commands and calling module’s method directly.
        • screen output like Lenovo smart display, youtube playing, TTS and more…
        • But this is not the kinds of out-of-box things. installation and tweak might not be so easy if you are not experienced.
          j.e.f.f Project Sponsor Module Developer @Egnos
          @egnos said in Start or not...?:
          What kind of sensors did you use to install on the doors? Wireless (WiFI, …) or wired?
          How did you display the open / closed door information on the MM? Do you have an example image?
          I used Schlage Connect locks which have a Z-Wave transceiver built-in for the doors, and the Chamberlain MyQ WiFi for the garage. Both integrate with the Wink hub. The Wink Hub sends out pubnub notifications when the state of connected devices changes. My module subscribes to the pubnub feed for the the Wink Hub and subsequently displays an icon depending on status.
          Here’s a screenshot:
          In it’s current status it only monitors doors (it was the only thing I found personally useful for display on my mirror). I had intended to extend this to monitor anything connected to the hub, but then I sold the house and all of the smart home gear with it when I moved to the UK. So I’ve ceased development on it.
          Is it possible to set a sentence to execute a command?
          For example: “Hey Google, set the temperature to 21 C °.” and the thermostat set the temperature at 21 C ° …
          Yes, but again, Magic Mirror is not doing any of the work here. Your voice assistant needs to have this integration into your smart thermostat. It doesn’t matter if you’re attempting to roll your own – say using GA to trigger Home Assistant to tap into Nest’s API – or are using an existing integration – say a Nest thermostat integrating with Apple Home Kit with Siri enabled. You could use a module to display feedback on the mirror in response to your voice command and another to report the current state of the thermostat – modules for both tasks exist in some form so they should be able to get you started.
          • E Offline
            Egnos @Peter
            @peter said in Start or not...?:
            Peter
            Ok, thanks Peter!
            In theory to start I would need:
            • Mini USB Microphone
            • Bluetooth Speaker
            • WiFi Router
            • Patience…:winking_face:
            after installing everything, I will need:
            • Sonoff 4ch pro (to control lights, etc…)
            • IP Camera
            • Smart Thermostat (what do you think about this? MAX! Wall Thermostat+)
            @sean said in Start or not...?:
            Thank you so much Sean.
            Spectacular module!
            Have you already tested it?
            @j-e-f-f said in Start or not...?:
            Ok, thanks j-e-f-f!
            Your form is very interesting and I congratulate you!!
            Sorry j-e-f-f…but I’m a noob :smiling_face_with_open_mouth_cold_sweat::
            could you explain to me what is the use and how does it work the connection between Wink Hub and Pubnub?
            Question for all:
            As a guide to get started …can i use this? Complete Setup Tutorial
            Or are there better guides?
            Thank you all!
              No worries!
              Wink Hub is a home automation appliance. It is meant as a single device to consolidate all your smart home devices into a single point of control. Here’s a link:
              https://www.wink.com/products/wink-hub-2/
              PubNub is a notification system API that Wink uses to broadcast devices status updates to anything that wishes to consume them.
              https://www.pubnub.com/
              • E Offline
                Egnos @j.e.f.f
                Ok, I understood.
                Wrong or pubnub is a paid service?
                Wink can only use Pubnub to send notifications or exist non-payment services?
                • E Offline
                  Egnos @Peter
                  Peter, how did you connect the GA item with the Sonoff?
                  Each Sonoff channel have an IP address? How does it work?
                    Peter
                    @Egnos: I think you should just start!
                    MM is a very funny project!
                    Buy a Raspberry Pi, SD card, find an old monitor, keyboard and mouse and go!
                    Burn an image on the SD card and try to get MM running.
                    You don’t need all the other stuff (you can add it later).
                    And I will give you some advice: after MM is working, save the config.js file (I saved it on a USB stick).
                    Then try to add or change a module; is it working: fine!
                    Is it not working: you still have the working config.js on the USB!
                    About the Sonoff: you do not need a RPI or MM to maken the Sonoff working.
                    The Sonoff is hardwired with the gardenlights; it has 1 IP adress with 4 channels.
                    You can use your cellphone or a 433 Mhz remote to switch the channels.
                    But I find it more fun to say: “Hey Google, turn on the fountain …”
                    Another advice: read, read, read, search, read and finally: ask here …
                    Peter
                    • E Offline
                      Egnos @Peter
                      @peter thanks for your precious advice!
                      I would like to start but for work I am often around Europe and time is always a little … !!
                      I’ll start soon … promised!:smiling_face_with_halo:
                      Ok, but how do you connect a sentence to GA with a command to Sonoff?
                      Thanks for your patience!
                        Peter
                        You have to make GA (on your cellphone) look for smart things.
                        Sonoff has an app (eWelink) but there are a lot of smart switches, thermostats and other.
                        After connecting the Sonoff with the app, it was recognized by GA.
                        But again: you do not need a MM to make smart things work.
                        Google home works even better; but building it yourself is a great part of the fun.
                        I started my MM project about a year ago and it took me a lot of time to make it the way I liked.
                        Now I am building a second one for my daughter and it takes me much less time.
                        But it is really a lot of fun to make your own personalized project.
                        Just try it!
                        Good luck!
                        Peter
                          @egnos It’s free to subscribe to receive notifications from apps or services that broadcast via PubNub. Likely there is a cost associated if you want to send notifications through PubNub, but I don’t know what that cost is.
                            Peter
                            @Egnos: one last advice: start with a Raspberry Pi 2B or 3B (not a zero or a 3B+).
                            I have 5 RPI’s (bought them all secondhand).
                            A lot of people buy a RPI and don’t know what to do with it.
                            Peter
                            • E Offline
                              Egnos
                              Sorry guys,
                              exist a wireless sensor (WiFi, bluetooth,etc…) that transmits the temperature to the Raspberry?
                              Maybe there is some MM module that manages the communication …
                              Good night! :sleeping_face:
                                Pi 3B has WiFi and bluetooth built-in. Pi 2B needs a USB dongle, but they’re not expensive.
                                If you want to display your house temperature, you need a smart thermostat like a Nest or an Ecobee. There exists a module for Nest, but I don’t know about Ecobee. Maybe you would relay that through Home Assistant?
                                If you want to display the weather outside, there are a bunch of weather modules available. I’m sure will suit your needs well.
                                  Peter
                                  I use cheap Xiaomi sensors in all rooms in my house, displayed on MM.
                                  Peter
                                  • E Offline
                                    Egnos @j.e.f.f
                                    Yes, I have Raspberry PI3.
                                    I would like to display the “real” outdoor temperature, if possible using a temperature sensor.
                                    I would like the real external and internal temperature (the internal one I will take from a smart thermostat) always be visible on my MM.
                                    The temperatures acquired by the various modules are estimates…correct?
                                    Peter
                                    Which module for MM do you use?
                                    Which xiaomi sensor do you use?
                                    I have another questions:
                                    • I bought the “Sonoff 4ch pro r2” but I do not understand how to make the Sonoff work together with the physical switch.
                                      Example:
                                      STEP 1: I turn on the light 1 with Sonoff
                                      STEP 2: I turn off the light 1 from the physical switch
                                      STEP 3: I turn on the light 1 with Sonoff
                                      It’s possible?
                                    • Is it possible to receive feedback from the “Sonoff”?
                                      Example: I would like to know if the house gate is open or closed or if the garden light is on, etc …
                                    • the “Sonoff 4ch pro r2” has a 433Mhz receiver (I think it is used to open the automatic gates …) and I would like to use it using a 433Mhz transmitter.
                                      Are there transmitters with 433Mhz for Raspberry?
                                      Have you tested someone?
                                      Could I use GA to open the gate at home?
                                    Thank you for your precious help!!
                                    • E Offline
                                      Egnos
                                      Hello everyone and happy new year!
                                      I returned the “Sonoff 4ch pro r2” because it was not for me!
                                      During the Christmas holidays I started the installation of the Magic Mirror with all its modules.
                                      These days I’m trying to install the module MMM-Assistantmk2 but I did not understand how to activate the assistant with my voice.
                                      In the configuration of MMM-Assistantmk2 module I did not find a way to insert a watchword to wake up the Assistant.
                                      Can you help me?
                                      Do you need to install modules like “MMM-Hotword” and “MMM-NotificationTrigger”?
                                      Thanks guys.
                                        A Former User @Egnos
                                        @egnos
                                        MMM-Hotword is needed if you want to activate it with voice hotword.
                                        • E Offline
                                          Egnos @Guest
                                          @egnos
                                          Thanks Sean!
                                          So if I only install the module “MMM-assistantmk2” how can I use it?
                                          So if I only install the module “MMM-assistantmk2” I can not do anything … correct?
                                            @egnos
                                            You can activate it with touching or clicking icon (If you have a touchable/clickable input method like touchscreen or mouse).
                                            Or You might have another input method like H/W button, or anything else. You can activate with other module which can emit notification. (Yes, Even default calendar module can activate this)
                                            I wanted to make this universal.
                                            • 2 / 3
