    Problems with certificate with MMM- Google Photos
    15 Posts 5 Posters 6.5k Views 5 Watching
    • JanneJ Offline
      Janne
      I am trying to implement Google Photo module. Thinking it could be kind of fun new year’s eve to invite all my guests to a shared photo folder.
      I have followed the instructions and have also received a credentials file that I have renamed to credentials.json and placed it in /home/pi/MagicMirror/modules/MMM-GooglePhotos
      But when I use the command node auth_and_test.js I receive an error.
      Any suggestions?
      • ? Offline
        [[global:former-user]] @Janne
        @janne
        Your credentials.json seems being maden wrongly. You might have missed something or chosen different option with my instruction when you made credentials.
        Open .json and see the first word. It should have {“installed” : ... or something similar.
        https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid
        I think you made something wrong on step 7.
        • JanneJ Offline
          Janne
          Hi Sean,
          You were right.
          I created a new project and now I get an ID when I send the command node auth_and_test.js
          I have more or less just copied your config example.
          But this is not valid in the config file.
          • Y Offline
            yawns Moderator
            The value for albumId should be written with quotation marks "AFktr.....26Z3s",
            Other than that I cannot spot any error in your snippet.
            • JanneJ Offline
              Janne
              Thanks… That solved it…
              You guys are awesome (y)
              So now my MMM is totally ready for New Years Eve.
              The menu is on a MMM-Memo and all guests is getting access to the google album so they can post pictures to the MMM.
              • E Offline
                Ernst-Jan
                Hi All,
                When I run the auth_and_test.js action on my PI. Will there be the popup for the approval on my google account but he will not go back.
                I some one a idee what wrong
                • ? Offline
                  [[global:former-user]] @Ernst-Jan
                  @ernst-jan
                  If you confirmed auth on your browser (Selecting your account and approval), Some code (4/ABCD1234BLAHBLAHBLAH....) will be shown after confirmation. Copy that code and paste it into your terminal shell (You can change the window with Ctrl+Tab)
                  • E Offline
                    Ernst-Jan @Guest
                    @seanif I click on my google account he will not log on
                    • ? Offline
                      @ernst-jan
                      When you click your account, this page should be shown. doesn’t ?
                      • E Offline
                        Ernst-Jan @Guest
                        @sean Sorry i only see this.
                        • ? Offline
                          @ernst-jan
                          Weird. Anyway, that is not problem of module itself. That page is hosted by google I cannot control. I don’t know what’s happening on your Google Account. Check your Google project again especially whether API is enabled.
                          • E Offline
                            Ernst-Jan @Guest
                            @sean It works.
                            • W Offline
                              wkeull @Ernst-Jan
                              @ernst-jan
                              What did you do to resolve this? I am having the exact same issue.
                              Thanks!
                              • E Offline
                                Ernst-Jan
                                @wkeull I have used another browser.
                                • W Offline
                                  wkeull
                                  Thanks,
                                  That did the trick, I used laukit on the RPI3.
