    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
    • LordyL Offline
      Lordy
      The two things were only added after the installation of “MMM-Page-Selector”.
      Do you know how I remove the “module name (red)” and the “module counter blue”?
      It is somehow related to the module.
      I hope Sean, can you help me?
      • ? Offline
        A Former User @Lordy
        @Lordy
        Remove postion of module. This module doesn’t need it.
        LordyL 1 Reply Last reply Reply Quote 0
        • LordyL Offline
          Lordy @Guest
          @Sean said in MMM-CalendarExt2:
          I tried it, unfortunately without success. Or what exactly do you mean? Here is my config.
          module:“MMM-CalendarExtMinimonth”,
          disabled: false,
          position: “bottom_bar”,
          pages: {main: ‘bottom_bar’},
          calendars: [ ],
          module: ‘MMM-CalendarExt2’,
          disabled: false,
          pages: {main: “bottom_bar”},
          rotateInterval: 5601000,
          scenes:[
          views: [“”],
          views:[
          title: “”,
          mode: “week”,
          colored: true,
          type: “row”,
          slotCount: 2,
          slotSubTitleFormat: “dddd”,
          slotTitleFormat: “DD.MMMM”,
          slotAltTitleFormat: “DD.MMMM”,
          slotMaxHeight:“325px”,
          calendars: [“xxx”],
          locale: “de”,
          maxItems:2000,
          hideOverflow: false,
          • ? Offline
            @Lordy
            Hmmm. this module would manage its hiding/revealing by itself. So there is no need set postion of this module itself. But you set the position by pages: {main: “bottom_bar”}, through MMM-Page-Selector by force.
            Unfortunately, MM would show the module name and id even when the module has nothing to draw at that position.
            Hmmm…
            I think the easiest way is to hide it by CSS.
            #module_7_MMM-CalendarExt2 {
              display:none;
            The only problem is, if you change the order of modules(adding a new module or removing) in configuration, the module Id will be changed. In that case, you should modify again.
            LordyL 1 Reply Last reply Reply Quote 1
            • LordyL Offline
              Lordy @Guest
              Thank you for your prompt reply. And always, you were right about that. :thumbs_up_medium-light_skin_tone:
              • N Offline
                nmeldre
                This post is deleted!
                • BKeyportB Offline
                  BKeyport Module Developer
                  Sean:
                  Looks like we’re getting screwed over here:
                  Starting February 15, 2021, G Suite accounts will only allow access to apps using OAuth. Password-based access will no longer be supported.
                  Calendar
                  If you use CalDAV to give an app or device access to your calendar, switch to a method that supports OAuth. We recommend the Google Calendar app [Web/iOS/Android] as the most secure app to use with your G Suite account.
                  • ? Offline
                    A Former User @nmeldre
                    @nmeldre
                    i’ve been asked this already countless times, however still the answer is same.
                    i regard week/month view as a kind of brief overview or summary of long periods. so have no idea to provide details on these both views.
                    Because;
                    • wrapping usually looks ugly anyhow.
                    • the more title means the less events to show at a same time in same area.
                    • can use transforming for abbreviation or using icon or assigning styles for better distinguishing than long text
                    • additional better views exist to show detailed info of more important and close future events. like upcoming or daily.
                    • real web or desktop application - google calendar and apple calendar - also don’t provide title wrapping in month style views.
                    So, sorry.
                    • ? Offline
                      A Former User @BKeyport
                      @BKeyport
                      hmm i don’t use G suit, so at this moment, have no idea how things going. I’ll research.
                      (maybe 3rd party converter module could be possible to solve that issue without modification of this module directly)
                      • BKeyportB Offline
                        BKeyport Module Developer @Guest
                        @Sean I figure Google’s gonna do that to main accounts sooner or later. GSuite is usually the test bed.
                        I’m likely going to be moving my calendar agenda system, depends on what my appointment manager supports.
                        • BKeyportB Offline
                          @Sean,
                          I’m trying to add an ICS file, but it’s throwing an error, but other calendars accepts it.
                          The url is http://www.tax.gov/calendar/employer/calendar.ics
                          Log from PM2 LOGS shows this error:
                          [CALEXT2] calendar:irs >> invalid date-time value: “2016-12-30T::”
                          Is it the US Government not knowing what’s going on, or is it a bug in the code?
                          Thanks!
                          • jdfraserJ Offline
                            jdfraser @Guest
                            @Sean
                            Thanks for the great module, it is the main reason for my Magic Mirror / picture frame.
                            Could you explain the syntax for using the “transform” command to change the title of an event to a shorter abbreviation (e.g. “jack climbing” = > “J.C.”)? I have some items in my calendar that are displayed on the monthly view with a title “Dinner: Taco Soup” and I would like to use transform to remove the "Dinner: " from the title. I have searched the documentation and the forum, but am having a tough time figuring out how I need to specify this in my config.js (or custom.css).
                            • ? Offline
                              A Former User @jdfraser
                              @jdfraser
                              Basically, read this.
                              https://github.com/eouia/MMM-CalendarExt2/wiki/Filtering-and-Sorting#transforming
                              You need some basic skills in JavaScript. Anyway, I’ll show some examples;
                              1. Original
                              I’ve added two events on 25th Dec. Lunch:Taco Soup Once and Dinner:Taco Soup Twiceon my Google calendar.
                              Hmmmm Taco Soup on Christmas, what a poor…
                              It will be shown like this on MMM-CalendarExt2 without transforming;
                              1. Remove Dinner:
                              transform: (event)=>{
                                event.title = event.title.replace("Dinner:", "")
                                return event
                              will make this;
                              1. give more transforming.
                                if (event.title.search("Dinner:") > -1) {
                                  event.icon = "emojione-pot-of-food"
                                  event.className = "myDinnerClass"
                                return event
                              I’ve added icon and specific CSS class selector. So you can define your CSS class on MagicMirror/css/custom.css like this;
                              .CX2 .myDinnerClass {
                                color: Black;
                                background-color: Yellow;
                              It will be shown like this;
                              0_1576691287656_a36b2008-915c-4bdb-8029-9786042beef9-image.png !
                              Of course, there would be more tricks if you know javascript somehow.
                              If you are not familiar with Javascript,… hmmm sorry for you. Anyway, this is DIY project. There is no ready-made out-of-box arts.
                              jdfraserJ 1 Reply Last reply Reply Quote 0
                              • C Offline
                                Clubjack
                                Hello together.
                                Is it possible to Show two different calendars, on two different pages (mmm-pages)?
                                • ? Offline
                                  A Former User @Clubjack
                                  @Clubjack
                                  Possible.
                                  You need 2 scenes which have independent views of your calendars.
                                  Then, read this;
                                  https://github.com/eouia/MMM-CalendarExt2/wiki/3.-Usage#user-defined-notification-trigger
                                  • C Offline
                                    Clubjack @Guest
                                    @Sean
                                    OK.
                                    But i want to same looking calendars with same View.
                                    I try it, with coping the mmm-calendarext2 and rename it to mmm-calendarext2.2
                                    S ? 2 Replies Last reply Reply Quote 0
                                      sdetweil @Clubjack
                                      @Clubjack ust make another scene like the 1st one with a different name, and put that on the next page
                                      • ? Offline
                                        @Clubjack said in MMM-CalendarExt2:
                                        This module will not work like that.
                                        Just make one more view with the same configured values.
                                        • jdfraserJ Offline
                                          jdfraser @Guest
                                          @Sean Thank you for your quick response! I will practice my Javascript :)
                                            sdetweil @jdfraser
                                            @jdfraser really no javascript , just stuff in config…
                                            you have for Ext2 a config section
                                            which has
                                            scenes: {
                                                     { name:  "scene1",
                                                         viewes: ["view1", "view2"]
                                                     { name:  "scene2",            // < --- make secodn scene that looks like the 1st
                                            Views: {
                                                     { name:  "view1"
                                                     {  name: "view2"
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 24
                                            • 25
                                            • 11 / 25
