    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      mrmagoo_83
      Trying to figure out two things:
      One: I got the event title to wrap which is what I want, but it causes issues when there is an event following the one that wraps as you can see in the picture.
      Second: How do I cut the overall height down of the whole thing? There is a lot of empty space, I’d like to limit the events per day to 3 and reduce the overall height of the calendar.
      • ? Offline
        A Former User @mrmagoo_83
        @mrmagoo_83
        1. I think you’ve modified CSS for sending event time to the right side, It could make the confusing wrapping. hmmm hard to explain. sorry for my poor English. What kind of method did you use? float right?, By default this module usually use flexbox model. Try another approach with using flex.
        2. adjust slotMaxHeight of view.
          https://github.com/eouia/MMM-CalendarExt2/wiki/2c4.-View:week,-month
          mrmagoo_83
          Ok, got the overall height down to manageable. I also reset the custom css work to time first, and all that. What I am looking to do is wrap the title of the event to multiple lines if it is too long, in doing so the event slot needs to increase, but when I do this, they still overlap like in the previous picture. I am very new to CSS so, I could easily have made a mistake.
          • C Offline
            code999 @Guest
            @Sean @mrdenmark
            Thanks for both of your help. I got it where I wanted it.
            @Sean Thanks for the module, its great! keep up the good work and awesome support.
            • C Offline
              code999
              I do have another question on the ics file. I am using one from a region but it does not seem to work, would you know why?
              i works for google, outlook and others. Thanks
              link… https://recollect.a.ssl.fastly.net/api/places/5C168558-A4F7-11E4-B82A-04208E6A6F5F/services/224/events.en.ics?client_id=B40A0DCC-1138-11EA-87AC-FC5DCE1212EE
                jani.karna
                I really appreciate the module and it is (almost) exactly what I want. I still looking the same thing as @mrmagoo_83 that I could wrap the events in multiple lines when needed.
                Also, is there a way to make events as wide as the column? Now it is slightly narrower. Here’s a picture of what I mean.
                https://www.dropbox.com/s/9iosscweizpthrb/IMG_0603.jpg?dl=0
                Can I also shrink the gap between events vertically somehow?
                  scuppasteve
                  I really like this module and unlike the regular Calendar app is able to deal with DST.
                  I have a calendar of just my kids chores to do today. All i want is to display the chores that are today, in the calendar they are all day events. So i would like the “ends in xx hours” to go away altogether ideally, but at worst i would just like it to say “Today”. Also I would like to make the slot background transparent and the slot text white. I know that is in CSS, but don’t see where to make it transparent.
                  			module: 'MMM-CalendarExt2',
                  				updateInterval: 1000*60*240,
                  				calendars : [
                  						scanInterval: 1000*60*240,
                  						url: "CAL URL",
                  			  	views: [
                  						mode: "current",
                  						hideOverflow: false,
                  						slotTitle: "Kid's Chores",
                  						slotMaxHeight: "75px",
                  						slotCount: 10,
                  						maxDays: 1,
                  						locale: "en",
                  						calendars: ["Chores"],
                  			  	scenes: [
                  • ? Offline
                    A Former User @jani.karna
                    @jani-karna
                    1. Slightly narrow event’s width is intentional to avoid margin of error on calculation. It is hardcoded. But if you want to modify it by yourself,
                      https://github.com/eouia/MMM-CalendarExt2/blob/a5d509ada997034f91e0790ad72e87512cb24c60/CALEXT2_Slot.js#L250
                    eventDom.style.width = width - 15 + "px"
                    Change 15 to what you want.
                    Tell me more exact details? Even a picture will help.
                    J 2 Replies Last reply Reply Quote 0
                    • ? Offline
                      A Former User @scuppasteve
                      @scuppasteve
                      The default method of displaying time on agenda views(current and upcoming) is defined as relative form. So, you can use just useEventTimeRelative: false, to display event time absolute format.
                      But what you want is just removing time of events from specific calendars or specific views, you can control it with CSS.
                      For example, when you want to hide time of all events from Chores calendar on current view, try this.
                      calendars : [
                          url: "CAL URL",
                          className: "CHORES_CAL"
                      Then, add this code to your css/custom.css
                      .CX2 .current .CHORES_CAL .eventTime {
                        display:none;
                      This means hide eventTime of CHORES_CAL of current view. Of course you can specify your target in other ways.
                      And you might need some additional CSS adjustment to beautify the empty area. Try it yourself.
                      • BKeyportB Online
                        BKeyport Module Developer @Guest
                        @Sean - This don’t seem to work. Did I break my code? (line numbers added to show result from error check) - MM won’t start with code enabled - “Please create file”
                        65: transform: (event) => {
                        66:	if (event.title.search("Recycle") > -1) {
                        67:		event.icon = "mdi:recycle",
                        68:	},
                        69:	return event
                        70: },
                        Results in:
                        Checking file...  /home/pi/MagicMirror/config/config.js
                        Line 65 col 46 'arrow function syntax (=>)' is only available in ES6 (use 'esversion: 6').
                        Line 68 col 33 Unexpected '}'.
                        Line 67 col 63 Expected an assignment or function call and instead saw an expression.
                        Line 67 col 64 Missing semicolon.
                        Line 68 col 34 Expected an identifier and instead saw ','.
                        Line 68 col 34 Expected an assignment or function call and instead saw an expression.
                        Line 68 col 35 Missing semicolon.
                        Line 69 col 45 Missing semicolon.
                        Thanks!
                          sdetweil @BKeyport
                          @BKeyport said in MMM-CalendarExt2:
                          “mdi:recycle”,
                          Remove the trailing comma
                            scuppasteve @Guest
                            @Sean That worked perfectly . How would you go about making the slot event background not be a black gradient? I just want the whole thing to be transparent.
                            • C Offline
                              cskenney
                              @Sean Similar to the Transform method used to identify a keyword in a title and change the icon (birthday is the example) is there a way to do the same thing (identify a key word) and change the color and background-color for that specific item?
                              My example would be if the word “Softball” is found in the title of a calendar entry it would transform the icon to a softball icon (already have this figured out). I also want to change the background-color and possibly the (font) color.
                                jani.karna @Guest
                                This post is deleted!
                                • BKeyportB Online
                                  @sdetweil - It gets worse.
                                  68: 	},
                                  69: 	return event
                                  70: },
                                  Line 67 col 63 Missing semicolon.
                                  0|mm     | WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:68
                                  0|mm     |                                                              },
                                  0|mm     |                                                               ^
                                  0|mm     | SyntaxError: Unexpected token ,
                                  0|mm     |     at new Script (vm.js:74:7)
                                  0|mm     |     at createScript (vm.js:246:10)
                                  0|mm     |     at Object.runInThisContext (vm.js:298:10)
                                  0|mm     |     at Module._compile (internal/modules/cjs/loader.js:678:28)
                                  0|mm     |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                  0|mm     |     at Module.load (internal/modules/cjs/loader.js:620:32)
                                  0|mm     |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                  0|mm     |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                  0|mm     |     at Module.require (internal/modules/cjs/loader.js:658:17)
                                  0|mm     |     at require (internal/modules/cjs/helpers.js:20:18)
                                    sdetweil @BKeyport
                                    68: }, < ------- remove THAT trailing comma
                                    Line 65 col 46 ‘arrow function syntax (=>)’ is only available in ES6 (use ‘esversion: 6’).
                                    need node V6, which we should be LONG past.
                                    do a node -v
                                    • C Offline
                                      cskenney @sdetweil
                                      @sdetweil @BKeyport I had the same issue with the arrow function. I did node -v and my system is v10.15.2. I was able to work around the issue by using the older notation like shown below.
                                      FYI - I just revised your code so you can copy and try it.
                                      65:  transform: function(event)  {
                                      67:	event.icon = "mdi:recycle";
                                      68: 	}
                                      69: 	return event;
                                      70: },
                                      EDIT - line 68 revised to fix an error
                                      • BKeyportB Online
                                        BKeyport Module Developer @cskenney
                                        @cskenney Your code almost got it. - had to remove the comma on line 68 there, but it now checks out…
                                        Just don’t seem to do anything yet. Tweaking some more.
                                        Actually, it’s doing exactly what it’s designed to do. It shows the icon for the event. I didn’t expect it to leave the title in place too. That’ll do perfect.
                                        • C Offline
                                          cskenney @BKeyport
                                          I’m glad it worked for you. I edited the code above to remove the comma in case someone else tries to use it. I originally missed it when I edited your code.
                                          • ? Offline
                                            A Former User @cskenney
                                            @cskenney said in MMM-CalendarExt2:
                                            Sorry for the late reply. At weekends, I rarely am in front of computer.
                                            You can define class in your CSS. then assign it into your transfrom code.
                                                event.className = "CLASS_RECYCLE" // in your css/custom.css, define color and bgcolor for this class
                                              return event
                                            C 1 Reply Last reply Reply Quote 1
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 24
                                            • 25
                                            • 8 / 25
