    Changing compliments?
    17 Posts 10 Posters 20.6k Views 9 Watching
      Algl
      Hello
      is there an option to define compliments in languages other than English ?
      thanks.
        Mykle1 Project Sponsor Module Developer @Algl
        @algl
        You can simply add your own compliments in any language you want and they will appear as you enter them.
        O 1 Reply Last reply Reply Quote 1
        • O Offline
          orbezo @Mykle1
          @mykle1 Would you happen to know about special characters?
          In the Spanish language, we “open” exclamation and interrogation marks (¡Text! ¿Text?), I’ve typed those characters directly, and they end up as a weird symbol once I run MM, then I tried specifying the encoding table (ISO-8859-1 and/or UTF-8) and it seems I missplaced the code, as MM told me there was no config.js file, then I tried using common HTML code using & # 1 6 1 ; (without spaces) for the “inverted” exclamation mark, and didn’t work either (I got the full “& # 1 6 1 ;” string displaced preceding the compliment’s normal text.
          Mykle1M ? 3 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @orbezo
            @orbezo
            Sorry, but I don’t know what special characters are available within MM. Perhaps someone else will chime in on that.
            However, if you have a font that has those special characters, you might then assign that font to the compliments module through your custom.css file.
            • ? Offline
              A Former User @orbezo
              @orbezo I think that might be caused by missing characters in Roboto fonts. As I know, Roboto font set with MM is not complete. There are some missed characters. You should install supplements by yourself.
              • ? Offline
                @orbezo
                See this;
                https://forum.magicmirror.builders/topic/5406/issue-with-polish-letters-font-missing-diacritical-marks/8
                • O Offline
                  orbezo
                  Thanks everyone for your answers, will read them carefully and follow your advice, will post back soon.
