    3 Posts 3 Posters 1.7k Views 3 Watching
    • U
      umeeq
      I tried downloading the files from the internet using…
      sudo curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
      and get the error below stating dependencies cant be found. I have built a mirror previously using the same instructions and now keep running into this issue.
      No Node.js upgrade necessary.
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Enumerating objects: 282, done.
      remote: Counting objects: 100% (282/282), done.
      remote: Compressing objects: 100% (251/251), done.
      remote: Total 282 (delta 34), reused 127 (delta 21), pack-reused 0
      Receiving objects: 100% (282/282), 385.56 KiB | 0 bytes/s, done.
      Resolving deltas: 100% (34/34), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      bash: line 113: npm: command not found
      idoodlerI 1 Reply Last reply Reply Quote 0
      • idoodlerI
        idoodler Module Developer @umeeq
        @umeeq This script requires thatnpm is already installed. Please double check that.
        • DæmonEyesD
          DæmonEyes
          In case you didn’t find a solution yet, a user by the name sdetweil just helped me with a similar problem with my RPi 3 B+ running the latest Rasbian Stretch.
          Here is the link to that discussion for everyone else who is stuck at this step too:
          https://forum.magicmirror.builders/topic/9636/stuck-at-unable-to-install-dependencies/8?page=1
