    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    SOLVED Modul Plug in RNV Abfrage
    Requests
    3100
    • G
      Guschdl last edited by
      Hello everyone,
      Can someone help me please.
      I’d like //github.com/silsha/rnv.js this module
      integrated into the Smart Mirror.
      This module is designed for querying the RNV stop in my hometown.
      Thanks in advance
      • yawns
        yawns Moderator last edited by
        The vendor provided an api-key really fast and sending queries to their server is somehow simple. To go on I need a more detailed description of what you want to see on your mirror.
        • G
          Guschdl @yawns last edited by
          @yawns said in Modul Plug in RNV Abfrage:
          Hello yawns.
          I want to see a ticker about a train station in the neary my home.
          I have a Api Key and I have two “Curl with link” with the data i wont to see…
          but i dont know this to use.
          I post the two links:
          Station 1:
          curl ‘http://rnv.the-agent-factory.de:8080/easygo2/rest/regions/rnv/modules/stationmonitor/element?hafasID=5553&time=null&uiSource=LINE’
          -H ‘User-Agent: easy.GO Client Android v1.2.1 (Mozilla/5.0 (Linux; Android 4.4.4; Nexus 4 Build/KTU84Q) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/33.0.0.0 Mobile Safari/537.36)’
          -H ‘Accept-Language: de’
          -H ‘Accept: application/json’
          Station 2:
          curl ‘http://rnv.the-agent-factory.de:8080/easygo2/rest/regions/rnv/modules/stationmonitor/element?hafasID=5553&transportFilter=1&time=null&uiSource=LINE’
          can you help me?
          • yawns
            Ok, understood. I don’t know if I find the time tomorrow. Maybe I have to wait until Wednesday to continue with the module. I keep you posted
            • G
              thanks you so much
              yawns 1 Reply Last reply Reply Quote 0
              • yawns
                yawns Moderator @Guschdl last edited by yawns
                @Guschdl
                All right, I’m almost done. The module will need some tweaking and some cleanup, but you can use it. I will provide some installation and configuration instructions this evening (my wife is working long this evening 😃 ). Feel free to provide feedback and improvements.
                G 2 Replies Last reply Reply Quote 3
                • G
                  @yawns
                  Woooow
                  Thank you so much.
                  I Have test ist…
                  it’s great
                  • G
                    Guschdl @yawns last edited by Guschdl
                    @yawns
                    it is possible to build a “Headline”?
                    I have found it 😃
                    Thank so sooooo much for the module
                    • yawns
                      @Guschdl
                      Hi, glad you like it. Please let me know if anything should be changed.
                      I updated the module.
                      • some more error handling
                      • added some tweaks in case the start time is after midnight, then the parsing failed
                      • added the alert ticker if some alert is present
                      • updated the readme
                      • removed odd default value for stationID from the module
                      Please run a “git pull” inside the MMM-RNV directory to receive the update. Please update your config file in case you left out the stationID.
                      Maybe @paviro or another moderator could mark this as resolved?
