    • Search
    SOLVED Flickering after 30-60 mins
    Troubleshooting
    1451
    • R
      rosenm last edited by
      MagicMirror always starts to flicker after 30-60 minutes. I tried on different monitors and only the monitor on HDMI starts to flicker.
      It looks like it’s only on HDMI, because if I connect via remote desktop, HDMI starts flickering but on remote desktop everything looks fine.
      If I use pm2 restart mm, MagicMirror restarts, the clock is counting about every 2 seconds, but the monitor doesn’t stop to flicker.
      After rebooting the PI everything works fine again. After 30-60 minutes same problem.
      • bhepler
        bhepler Project Sponsor last edited by
        This post may help you. At the very least, check out the YouTube link and let me know if the graphical errors you’re experiencing are the same.
        • Hein-Jan
          Hein-Jan last edited by
          I did have the same problem as @bhepler. Switching from fake KMS to full KMS solved the problem.
          Hein-Jan
          • lavolp3
            lavolp3 Module Developer last edited by
            @rosenm Same problem for me.
            Only occured on my MM with the fake kms driver activated.
            I don’t know the reason yet.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • R
              rosenm @bhepler last edited by
              @bhepler
              Thanks this solved it.
              Does anyone know why this is a problem with the fake one?
              • A
                afrench10 @Hein-Jan last edited by
                @hein-jan I had the same problem as well, switching from fkms to kms. When I switched to kms, the flickering went away, but I was unable to rotate 90 degrees for my vertical display.
                Have you come across any solutions? Or has anybody else? Thanks in advance for your insight!
                Hein-Jan 1 Reply Last reply Reply Quote 0
                  surger13 Project Sponsor last edited by
                  I had the problems after updating to 2.6.0 too. I noticed that the fading stuttered after the start of MM at the newsfeed module. After some time the whole monitor flickered like in the video.
                  It helped me to comment out both kms drivers in the config.txt. The load of the system was also lower afterwards. The problem with the high load because of electron seems to be no longer present. At least for me.
                  #dtoverlay=vc4-kms-v3d
                  #dtoverlay=vc4-fkms-v3d
                  • D
                    dazza120 last edited by dazza120
                    Hi how do I switch to the KMS drivers, I’m not noticing the flickers as my tv gets turned off, but have noticed memory on the Pi 3B+ is getting taxed big time and after about 2days the memory will go down to single figures before it just goes black screen, I’ve tried to use watchdog but that just crashes MM to desktop and doesn’t do the pm2 restart mm. Would switching to the KMS driver make it lighter? For me CPU usage is 1.something percent so it’s hardly using CPU but memory it’s killing it
                    • Hein-Jan
                      Hein-Jan @afrench10 last edited by
                      @afrench10
                      A small part of the MichMich set-Up instructions:
                      ℹ️ Activating the Open GL drive can also be accomplished by using the raspi-config tool by running sudo raspi-config. Go to the Advanced Options menu and select A7 GL Driver. Next, select the G1 GL (Full KMS) OpenGL desktop driver with full KMS. Note that this option will be selected in the menu even when the GL drive is not yet configured.
                      Unfortunately, as a result, the display_rotate=1 (see below) won't have any effect on the display. If you want to rotate the display when the Open GL driver is in use, we need to use the xrandr tool which allows us to rotate the display when in desktop mode. To do so, edit the autostart file:
                      nano ~/.config/lxsession/LXDE-pi/autostart
                      And add the following line:
                      @xrandr --output HDMI-1 --rotate right
                      That should solve your problem.
                      Kind Regards
                      Hein-Jan
                      • A
                        @hein-jan Thanks for sending your reply! I saw that in the set-up instructions as well, but for some reason, I couldn’t get xrandr to rotate the display. I was curious if we needed the GL Driver at all, but based on recent comments in this thread, it seems that others don’t. I commented the Driver out and things seem to be working fine now. Thanks again!
