    MMM-WunderGround not updating after a few hours
    5 Posts 3 Posters 4.2k Views 5 Watching
    • L Offline
      lsfourwheeler
      I have installed the MMM-Wunderground module an have been running it for a couple week but cannot solve an issue with it continually ceasing to update until MM is restarted. It does this after about 8-12 hours. I have checked the PM2 logs and they do not show any related errors. When I use the NPM start dev command an watch the console I have found an error that says:
      "The ‘Access-Control-Allow-Origin’ header has a value ‘http://www.wunderground.com’ that is not equal to the supplied origin. Origin ‘http://localhost:8080’ is therfore not allowed access.
      This is followed by a message that says “MMM-WunderGround:* Could not load weather.” I have seen other people with this issue but no publicly posted solution. Does anyone have a suggestion? Thanks.
      • L Offline
        lsfourwheeler
        It’s still updating after this error but I will monitor more and see if another error occurs before it stops updating entirely.
          RedNax Module Developer
          Changed around some things in the way information is retrieved from weatherunderground. It’s on github, please test.
          • O Offline
            ostfilinchen @RedNax
            @RedNax now i get the error, that the key does not exist. But it does. The next updating the weather, it works again.
            • L Offline
              lsfourwheeler @lsfourwheeler
              I will update and check the functionality. Thanks.
              @RedNax said in MMM-WunderGround not updating after a few hours:
