    Mirror supplier in Norway?
    28 Posts 8 Posters 25.7k Views 8 Watching
      Stellanova
      Does anyone know where we can get a two way mirror (acrylic) in Norway?
      • P Offline
        Phantom @Stellanova
        @Stellanova Jeg ville gått for glass speil siden du ikke kan bruke touch med acryl. Når det gjelder levrandør ville jeg nok sett i england eller andre steder for prisen i norge er over dobbelt av UK.
        CatoC S 2 Replies Last reply Reply Quote 0
        • CatoC Offline
          Cato Module Developer @Phantom
          @Phantom Even if the mirror is cheaper in England, what about the freight cost?
          And do really glass work with a touchscreen?
          • P Offline
            Phantom @Cato
            @Cato Well yes it would be cheaper to buy the glass from the UK cuz Norwegian suppliers need to pay freight and tax before adding what they want to make on it. This type of glass is not something thay have in stock so they to will have to order, remeber we are making a magic mirror so the glass should be made for this. Smart glass is made to cover tv or a computer screen so the colors dont get distorted.
            Yes touch will work behind glass, there is normaly two ways you do thtis. IR frame wich is cheap and great if you have a frame on the mirror. I always use pcap screens since i can make the mirror bordeless with that. pcap is (Projected Capacitive touch screen) its more expensive but looks great.
              Stellanova @Phantom
              @Phantom Takk for tipset, ja det var veldig dyr hær i Norge. Jeg har ikke tenkt å gå for touch da. Vent så det finnes toveis speil av glass, jeg gikk ut fra at det bare fantes av akryl.
              • P Offline
                Phantom @Stellanova
                @Stellanova said in Mirror supplier in Norway?:
                He he, det finnes i glass også som er det beste siden acryl kan vregnge bilde litt. Skal du bare ha tv på badet?
                  dakipro
                  I was planning on buying picture frame with the glass and then try the foil on it. Any tips where the foil could be purchased?
                  I saw that biltema hadde slik folie, but not sure if it is available anymore. Any tips on where to find the foil?
                    AAPS
                    Does anyone know where I could get a cheap mirror in the US?
                    • P Offline
                      Phantom @dakipro
                      @dakipro Well foile can be used but you have to get a hi D number or else you will not see the screen. You will need to buy from a solar window tint provider for homes. This is the clearest http://www.vindusfolie-nettbutikk.no/shop/product/silver-35-ext-solfilm?tm=solfilm-til-hus
                      Hope this helps
                      CatoC D 2 Replies Last reply Reply Quote 0
                      • CatoC Offline
                        @Phantom have you tested this? I’m wondering about the reflective properties. Will the reflection be too dark (ie no wife acceptance)…
                        • 1 / 3
