    MMM-Hover node-modul error
    6 Posts 4 Posters 2.1k Views 2 Watching
      Skorpionbird
      Hello togheter i has installed the MMM-Hover Modul but there is an problem. i recive this error message:
      Whoops! There was an uncaught exception…
      Error: The module ‘/home/pi/MagicMirror/modules/MMM-Hover/node_modules/epoll/build/Release/epoll.node’
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 59. This version of Node.js requires
      NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
      the module (for instance, using npm rebuild or npm install).
      at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:166:20)
      at Object.Module._extensions…node (module.js:671:18)
      at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:166:20)
      at Module.load (module.js:561:32)
      at tryModuleLoad (module.js:504:12)
      at Function.Module._load (module.js:496:3)
      at Module.require (module.js:586:17)
      at require (internal/module.js:11:18)
      at bindings (/home/pi/MagicMirror/modules/MMM-Hover/node_modules/bindings/bindings.js:84:48)
      at Object. (/home/pi/MagicMirror/modules/MMM-Hover/node_modules/epoll/epoll.js:1:192)
      Launching application.
      i hope some one can help me with this issue.
      Regards Skorpionbird
        AxLed Module Developer
        I had a similar problem once with anoter module, this helped
        #Change into the modules directory
        cd modules/MMM-Hover
        # Rebuild module for the correct elecron version
        npm rebuild --runtime=electron --target=$(../../node_modules/electron/cli.js --version) --disturl=https://atom.io/download/atom-shell --build-from-source
        AxLED
          @Skorpionbird
          I am not sure if the code mentioned above works, i just saw you have an node problem, my problem was a electron problem.
          AxLED
            bhepler Module Developer
            Please use the Markdown features of the board to assist others in reading your code and log files.
            On another note, when the error message says:
            Error: The module '/home/pi/MagicMirror/modules/MMM-Hover/node_modules/epoll/build/Release/epoll.node’
            Did you try those commands?
            cd /home/pi/MagicMirror/modules/MMM-Hover
            npm rebuild
              Skorpionbird
              dosn`t work with npm rebuild
              any ideas
                AdnanAhmed97
                Rebuild the electron
                cd MagicMirror/modules/MMM-Hover
                npm install --save-dev electron-rebuild
                ./node_modules/.bin/electron-rebuild
