    MMM-Bible
    2 Posts 2 Posters 1.8k Views 1 Watching
      Steed
      open up your compliments.js module and paste the github text under “anytime/morning/afternoon/evening” according to what time you would like to feel inspired.
      // Module config defaults.
      defaults: {
      compliments: {
      anytime: [
      /// PASTE github text from this link https://github.com/TJSteed/MMM-Bible/blob/master/Ecclesiasticus to have a random wisdom quote from the wisdom book of the bible called Ecclesiasticus.
      This is ecclesiasticus. better known as sirach. it is one of the wisdom books of the catholic bible.
      next for the project are the following wisdom books Psalms, Proverbs, Ecclesiastes, Song of Songs, and Wisdom. i plan on doing each book listed for this module i am creating.
      the only wisdom book i will not be doing is job because his book is a bit too story like and is best enjoyed in order verse by verse or you wont take much from it. ecclesiasticus is my favorite book so i did it first.
      • bheplerB Offline
        bhepler Module Developer
        You probably should not update your compliments.js file. If you update your MagicMirror framework, the new version will overwrite your changes to the module.
        You probably want to add this modification to the module configuration in the /home/pi/MagicMirror/config/config.js file.
