    MMM Remote Controle - starting issus
    13 Posts 3 Posters 5.2k Views 3 Watching
    • E Offline
      Ernst-Jan @Ernst-Jan
      @ernst-jan said in MMM Remote Controle - starting issus:
      npm/logs
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
      2 info using npm@5.6.0
      3 info using node@v9.11.2
      4 verbose stack Error: missing script: start
      4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:151:19)
      4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:61:5
      4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
      4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:402:5
      4 verbose stack at checkBinReferences
      (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:357:45)
      4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:400:3)
      4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
      4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:348:12
      4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16
      4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
      5 verbose cwd /home/pi/.local/share/Trash/files/MMM-Remote-Control/MMM-Remote-Control
      6 verbose Linux 4.14.79-v7+
      7 verbose argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
      8 verbose node v9.11.2
      9 verbose npm v5.6.0
      10 error missing script: start
      11 verbose exit [ 1, true ]
      • E Offline
        Ernst-Jan
        @sdetweil said in MMM Remote Controle - starting issus:
        npm start dev
        /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js
          sdetweil @Ernst-Jan
          @ernst-jan don’t understand your reply.
          From the MagicMirror folder do
          npm start dev
          Then as per my previous instructions
          • E Offline
            Ernst-Jan
            Starting MagicMirror: v2.6.0
            Loading config …
            WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
            Loading module helpers …
            Initializing new module helper …
            No helper found for module: helloworld.
            All module helpers loaded.
            Starting server on port 8080 …
            Server started …
            Sockets connected & modules started …
            Whoops! There was an uncaught exception…
            { Error: listen EADDRINUSE 127.0.0.1:8080
            at Object._errnoException (util.js:1024:11)
            at _exceptionWithHostPort (util.js:1046:20)
            at Server.setupListenHandle [as _listen2] (net.js:1351:14)
            at listenInCluster (net.js:1392:12)
            at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
            code: ‘EADDRINUSE’,
            errno: ‘EADDRINUSE’,
            syscall: ‘listen’,
            address: ‘127.0.0.1’,
            port: 8080 }
            Launching application.
            main.js:343 Config file is missing! Please create a config file.
            loadConfig @ main.js:343
            19:03:05.148
              sdetweil @Ernst-Jan
              @ernst-jan it is already running. Need to stop it before starting again
                sdetweil @Ernst-Jan
                @ernst-jan and syntax errors
                From mm folder do
                node tests/configs/check_config.js
                Start at the top and correct errors reported, rerun til no errors, then do the npm start again
                  robiv8
                   		module: ‘MMM-Remote-Control’
                   		// uncomment the following line to show the URL of the remote control on the mirror
                   		position: ‘bottom_left’
                   		// you can hide this module afterwards from the remote control itself
                  i am missing a semilicon
                  type this
                  , position: ‘bottom_left’
                    sdetweil @robiv8
                    @robiv8 two close brace, only one open
                    Comma Missing after the module line
                      robiv8
                      @robiv8 said in MMM Remote Controle - starting issus:
                      You are right! 1 close brace are to much
                      And comma missing:
                      This
                      or this
                                      module: ‘MMM-Remote-Control’,
                      is the same.
