MMM Remote Controle - starting issus
Is there a way to see whats wrong with the config of your last module.
My last module is remote controle.
I have set address: 0.0.0.0, and ipWhitelist: [],
module: ‘MMM-Remote-Control’
position: ‘bottom_left’
When i start with pm2 start mm i see only this error. When i remove te module MM start normal.0|mm | Starting MagicMirror: v2.6.0
0|mm | Loading config …
0|mm | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
0|mm | Loading module helpers …
0|mm | Initializing new module helper …
0|mm | Module helper loaded: updatenotification
0|mm | No helper found for module: helloworld.
0|mm | All module helpers loaded.
0|mm | Starting server on port 8080 …
0|mm | Server started …
0|mm | Connecting socket for: updatenotification
0|mm | Sockets connected & modules started …
0|mm | Launching application. -
@ernst-jan do
npm start devThen select the console tab of the developers environment, and look for any errors (red text)
@ernst-jan
npm ERR! missing script: startnpm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2019-01-31T17_06_55_736Z-debug.log -
@ernst-jan in the magic mirror folder
@ernst-jan said in MMM Remote Controle - starting issus:
npm/logs
1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
2 info using npm@5.6.0
3 info using node@v9.11.2
4 verbose stack Error: missing script: start
4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:151:19)
4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:61:5
4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:402:5
4 verbose stack at checkBinReferences (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:357:45)
4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:400:3)
4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:348:12
4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16
4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
5 verbose cwd /home/pi/.local/share/Trash/files/MMM-Remote-Control/MMM-Remote-Control
6 verbose Linux 4.14.79-v7+
7 verbose argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
8 verbose node v9.11.2
9 verbose npm v5.6.0
10 error missing script: start
11 verbose exit [ 1, true ] -
@sdetweil said in MMM Remote Controle - starting issus:
npm start dev
/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js
@ernst-jan don’t understand your reply.
From the MagicMirror folder do
npm start devThen as per my previous instructions
Loading config …
Server started …
Whoops! There was an uncaught exception…
{ Error: listen EADDRINUSE 127.0.0.1:8080
at Object._errnoException (util.js:1024:11)
at _exceptionWithHostPort (util.js:1046:20)
at Server.setupListenHandle [as _listen2] (net.js:1351:14)
at listenInCluster (net.js:1392:12)
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
code: ‘EADDRINUSE’,
errno: ‘EADDRINUSE’,
syscall: ‘listen’,
address: ‘127.0.0.1’,
port: 8080 }
Launching application.main.js:343 Config file is missing! Please create a config file.
loadConfig @ main.js:343
19:03:05.148 -
@ernst-jan it is already running. Need to stop it before starting again
@ernst-jan and syntax errors
From mm folder do
node tests/configs/check_config.jsStart at the top and correct errors reported, rerun til no errors, then do the npm start again
{ module: ‘MMM-Remote-Control’ // uncomment the following line to show the URL of the remote control on the mirror position: ‘bottom_left’ // you can hide this module afterwards from the remote control itself } },i am missing a semilicon
type this
, position: ‘bottom_left’ -
@robiv8 two close brace, only one open
Comma Missing after the module line
@robiv8 said in MMM Remote Controle - starting issus:
You are right! 1 close brace are to muchAnd comma missing:
This{ module: ‘MMM-Remote-Control’ , position: ‘bottom_left’ },or this
{ module: ‘MMM-Remote-Control’, position: ‘bottom_left’ },is the same.
