    MMM Remote Controle - starting issus
    13 Posts 3 Posters 5.1k Views 3 Watching
      sdetweil @Ernst-Jan
      @ernst-jan in the magic mirror folder
      • E Offline
        Ernst-Jan @Ernst-Jan
        @ernst-jan said in MMM Remote Controle - starting issus:
        npm/logs
        1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
        2 info using npm@5.6.0
        3 info using node@v9.11.2
        4 verbose stack Error: missing script: start
        4 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:151:19)
        4 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:61:5
        4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
        4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:402:5
        4 verbose stack at checkBinReferences
        (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:357:45)
        4 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:400:3)
        4 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
        4 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:348:12
        4 verbose stack at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16
        4 verbose stack at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
        5 verbose cwd /home/pi/.local/share/Trash/files/MMM-Remote-Control/MMM-Remote-Control
        6 verbose Linux 4.14.79-v7+
        7 verbose argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
        8 verbose node v9.11.2
        9 verbose npm v5.6.0
        10 error missing script: start
        11 verbose exit [ 1, true ]
        • E Offline
          Ernst-Jan
          @sdetweil said in MMM Remote Controle - starting issus:
          npm start dev
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js
            sdetweil @Ernst-Jan
            @ernst-jan don’t understand your reply.
            From the MagicMirror folder do
            npm start dev
            Then as per my previous instructions
            • E Offline
              Ernst-Jan
              Starting MagicMirror: v2.6.0
              Loading config …
              WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
              Loading module helpers …
              No helper found for module: helloworld.
              All module helpers loaded.
              Starting server on port 8080 …
              Server started …
              Sockets connected & modules started …
              Whoops! There was an uncaught exception…
              { Error: listen EADDRINUSE 127.0.0.1:8080
              at Object._errnoException (util.js:1024:11)
              at _exceptionWithHostPort (util.js:1046:20)
              at Server.setupListenHandle [as _listen2] (net.js:1351:14)
              at listenInCluster (net.js:1392:12)
              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
              code: ‘EADDRINUSE’,
              errno: ‘EADDRINUSE’,
              syscall: ‘listen’,
              address: ‘127.0.0.1’,
              port: 8080 }
              Launching application.
              main.js:343 Config file is missing! Please create a config file.
              loadConfig @ main.js:343
              19:03:05.148
                sdetweil @Ernst-Jan
                @ernst-jan it is already running. Need to stop it before starting again
                  sdetweil @Ernst-Jan
                  @ernst-jan and syntax errors
                  From mm folder do
                  node tests/configs/check_config.js
                  Start at the top and correct errors reported, rerun til no errors, then do the npm start again
                    robiv8
                     		module: ‘MMM-Remote-Control’
                     		position: ‘bottom_left’
                    i am missing a semilicon
                    type this
                    , position: ‘bottom_left’
                      sdetweil @robiv8
                      @robiv8 two close brace, only one open
                      Comma Missing after the module line
                        robiv8
                        @robiv8 said in MMM Remote Controle - starting issus:
                        You are right! 1 close brace are to much
                        And comma missing:
                        This
                        or this
                                        module: ‘MMM-Remote-Control’,
                        is the same.
