    Change Compliments
    17 Posts 7 Posters 7.0k Views 7 Watching
      dgregory19 @THeStigh
      @thestigh I’ll try this. It looks different then what is supplied by MM. I think i have the syntax wrong and haven’t learned yet how to do the coding. Thanks.
      • T Offline
        THeStigh @dgregory19
        @dgregory19 As @Mykle1 stated, there is another way.
        Personally, I prefer to have all custom configurations in one single file config.js and all custom css in the custom.css, by this I can add/remove/replicate configurations/modules installed from device to device. Makes it easy to backup :)
        Another tip;
        Above each module in config.js, you can add disabled: false / true, to temporarily make a module not load on MM. Like this:
        			disabled: false,
        			module: 'MMM-Remote-Control'
        If you need anymore help, please let me know.
          dgregory19
          Thanks everyone! Figured it out. Onto breaking something else…
          • C Offline
            CheapDad
            My apologies for resurrecting a dead thread, but it seemed like keeping all similar questions to one thread might be useful to others.
            I was happy with the default compliments, but wanted to customize them to the user. I copied the compliments entries from compliments.js and inserted them into my config.js. I don’t get any errors when I run config:check, but the compliments no longer appear on the screen. Here’s my code:
            			module: "compliments",
            			position: "lower_third",
            			config:  {
            				compliments: {
            					anytime: ["Hey there Emma!"],
            					morning: ["Good morning, Emma!", "Enjoy your day!", "How was your sleep?"],
            					afternoon: ["Hello, Emma!", "You look beautiful!", "Looking good today!"],
            					evening: ["Wow, you look great!", "You look nice!", "Hi, Emma!"],
            					"....-01-01": ["Happy new year!"]
              sdetweil @CheapDad
              @cheapdad u should have gotten an error in the window where u start MM…
              I do copying your stuff
              SyntaxError: Unexpected token '}'
                  at wrapSafe (internal/modules/cjs/loader.js:1060:16)
                  at Module._compile (internal/modules/cjs/loader.js:1108:27)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                  at Module.load (internal/modules/cjs/loader.js:992:32)
                  at Module._load (internal/modules/cjs/loader.js:885:14)
                  at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
                  at loadApplicationPackage (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16)
                  at Object.<anonymous> (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9)
                  at Module._compile (internal/modules/cjs/loader.js:1152:30)
              and npm config:check says
              (base) sam@sams:~/MagicMirror$ npm run config:check
              > magicmirror@2.15.0 config:check /home/sam/MagicMirror
              > node js/check_config.js
              [24.04.2021 15:25.20.258] [INFO]  Checking file...  /home/sam/MagicMirror/config/config.js
              [24.04.2021 15:25.20.270] [ERROR] Your configuration file contains syntax errors :(
              [24.04.2021 15:25.20.270] [ERROR] Line 56 column 7: Parsing error: Unexpected token {
              shorter answer, u are missing a }
              • C Offline
                CheapDad @sdetweil
                @sdetweil That’s the strange thing, I’m not getting any errors when I run npm run config:check.
                Unfortunately, I had to rebuild my config.js since I installed a module, edited config.js and ended up with a blank screen that no commenting the config.js entries didn’t fix.
                Here’s the new (old) compliments entries:
                			config:  {
                				compliments: {
                And my npm run config:check:
                pi@emmasmagicmirror:~/MagicMirror $ npm run config:check
                > magicmirror@2.15.0 config:check /home/pi/MagicMirror
                [24.04.2021 16:58.15.197] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                [24.04.2021 16:58.15.352] [INFO]  Your configuration file doesn't contain syntax errors :)
                  sdetweil @CheapDad
                  @cheapdad
                  the thing is
                      module:"name",
                      position:"...",
                          compliments: {
                          }   //< ---- this brace is missing
                  get bitvise ssh client, then u can have a file manager view from windows
                  and use notepad++ to edit  and see the  brace, paren and bracket matching
                  • C Offline
                    CheapDad
                    Forgive me for pursuing this, but I see an opportunity to really learn here. When I look at my code, I have closed all of my braces:
                    			config:  {  \\ open
                    				compliments: {  \\open
                    		}   \\close
                    	}, \\close
                    			module: "weather",
                    If I add another closing brace, won’t I have an error because there is no opening brace?
                    On the suggestion for bitvise ssh, I’m working directly off the pi itself. I would love to run the entire MM configuration in a vm until it is right and then simply copy that over to the pi, but that’s a bit beyond my knowledge level.
                      sdetweil @CheapDad
                      @cheapdad u are missing the open brace for the module block in this last picture (see my layout above)
                      if you use bitvise then u dont have to edit ON the pi keyboard…
                      also gives u an ssh window to execute commands, again NOT on the pi keyboard
                      u can run raspian x86 in a vm on pc…
                      • C Offline
                        CheapDad
                        I think I figured it out and see where I needed a third closing brace. The weird thing is that Compliments seems to be the only module that doesn’t start with an opening brace, where all the others appear to. If I add an opening brace to it, I get an error. If I leave it out, it runs.
