    Change Compliments
    17 Posts 7 Posters 7.7k Views 7 Watching
    • T
      THeStigh
      Yes, you need to create them within config.js
      This is my config (replace ‘bla bla bla’ as you want):
      		module: "compliments",
      		position: "lower_third",
      			compliments: {
      				morning: [
      					"bla bla bla",
      					"bla bla bla"
      				afternoon: [
      					"bla bla bla",
      					"bla bla bla"
      				evening: [
      					"bla bla bla",
      					"bla bla bla"
      			updateInterval: 30000,
      			remoteFile: null,
      			fadeSpeed: 4000,
      			morningStartTime: 3,
      			morningEndTime: 12,
      			afternoonStartTime: 12,
      			afternoonEndTime: 17
      Please mark answer as correct and topic as Solved (if this solved your issue) :)
      D 1 Reply Last reply Reply Quote 2
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @dgregory19
        @dgregory19
        Or, use a remote file (as per the compliments readme) so as not to encumber the config.js file with a lengthy entry.
        • cowboysdudeC
          OR just use another module…
          https://github.com/cowboysdude/MMM-NiceThings
            dgregory19 @THeStigh
            @thestigh I’ll try this. It looks different then what is supplied by MM. I think i have the syntax wrong and haven’t learned yet how to do the coding. Thanks.
            • T
              THeStigh @dgregory19
              @dgregory19 As @Mykle1 stated, there is another way.
              Personally, I prefer to have all custom configurations in one single file config.js and all custom css in the custom.css, by this I can add/remove/replicate configurations/modules installed from device to device. Makes it easy to backup :)
              Another tip;
              Above each module in config.js, you can add disabled: false / true, to temporarily make a module not load on MM. Like this:
              			disabled: false,
              			module: 'MMM-Remote-Control'
              If you need anymore help, please let me know.
                dgregory19
                Thanks everyone! Figured it out. Onto breaking something else…
                  CheapDad
                  My apologies for resurrecting a dead thread, but it seemed like keeping all similar questions to one thread might be useful to others.
                  I was happy with the default compliments, but wanted to customize them to the user. I copied the compliments entries from compliments.js and inserted them into my config.js. I don’t get any errors when I run config:check, but the compliments no longer appear on the screen. Here’s my code:
                  			config:  {
                  				compliments: {
                  					anytime: ["Hey there Emma!"],
                  					morning: ["Good morning, Emma!", "Enjoy your day!", "How was your sleep?"],
                  					afternoon: ["Hello, Emma!", "You look beautiful!", "Looking good today!"],
                  					evening: ["Wow, you look great!", "You look nice!", "Hi, Emma!"],
                  					"....-01-01": ["Happy new year!"]
                    sdetweil @CheapDad
                    @cheapdad u should have gotten an error in the window where u start MM…
                    I do copying your stuff
                    SyntaxError: Unexpected token '}'
                        at wrapSafe (internal/modules/cjs/loader.js:1060:16)
                        at Module._compile (internal/modules/cjs/loader.js:1108:27)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                        at Module.load (internal/modules/cjs/loader.js:992:32)
                        at Module._load (internal/modules/cjs/loader.js:885:14)
                        at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
                        at loadApplicationPackage (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16)
                        at Object.<anonymous> (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9)
                        at Module._compile (internal/modules/cjs/loader.js:1152:30)
                    and npm config:check says
                    (base) sam@sams:~/MagicMirror$ npm run config:check
                    > magicmirror@2.15.0 config:check /home/sam/MagicMirror
                    > node js/check_config.js
                    [24.04.2021 15:25.20.258] [INFO]  Checking file...  /home/sam/MagicMirror/config/config.js
                    [24.04.2021 15:25.20.270] [ERROR] Your configuration file contains syntax errors :(
                    [24.04.2021 15:25.20.270] [ERROR] Line 56 column 7: Parsing error: Unexpected token {
                    shorter answer, u are missing a }
                      CheapDad @sdetweil
                      @sdetweil That’s the strange thing, I’m not getting any errors when I run npm run config:check.
                      Unfortunately, I had to rebuild my config.js since I installed a module, edited config.js and ended up with a blank screen that no commenting the config.js entries didn’t fix.
                      Here’s the new (old) compliments entries:
                      			config:  {
                      				compliments: {
                      And my npm run config:check:
                      pi@emmasmagicmirror:~/MagicMirror $ npm run config:check
                      > magicmirror@2.15.0 config:check /home/pi/MagicMirror
                      [24.04.2021 16:58.15.197] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                      [24.04.2021 16:58.15.352] [INFO]  Your configuration file doesn't contain syntax errors :)
                        sdetweil @CheapDad
                        @cheapdad
                        the thing is
                            module:"name",
                            position:"...",
                                compliments: {
                                }   //< ---- this brace is missing
                        get bitvise ssh client, then u can have a file manager view from windows
                        and use notepad++ to edit  and see the  brace, paren and bracket matching
                          CheapDad
                          Forgive me for pursuing this, but I see an opportunity to really learn here. When I look at my code, I have closed all of my braces:
                          			config:  {  \\ open
                          				compliments: {  \\open
                          		}   \\close
                          	}, \\close
                          			module: "weather",
                          If I add another closing brace, won’t I have an error because there is no opening brace?
                          On the suggestion for bitvise ssh, I’m working directly off the pi itself. I would love to run the entire MM configuration in a vm until it is right and then simply copy that over to the pi, but that’s a bit beyond my knowledge level.
                            sdetweil @CheapDad
                            @cheapdad u are missing the open brace for the module block in this last picture (see my layout above)
                            if you use bitvise then u dont have to edit ON the pi keyboard…
                            also gives u an ssh window to execute commands, again NOT on the pi keyboard
                            u can run raspian x86 in a vm on pc…
                              CheapDad
                              I think I figured it out and see where I needed a third closing brace. The weird thing is that Compliments seems to be the only module that doesn’t start with an opening brace, where all the others appear to. If I add an opening brace to it, I get an error. If I leave it out, it runs.
                                sdetweil @CheapDad
                                @cheapdad EVERY module MUST start with an opening brace…
                                ignore any typos you find somewhere else…
                                see my module diagram above
                                  CheapDad @sdetweil
                                  @sdetweil Got it.
                                    sdetweil @CheapDad
                                    @cheapdad I sent u a chat message
