    Change Compliments
    17 Posts 7 Posters 7.7k Views 7 Watching
      dgregory19
      I would like to change the default compliments but dont see them under compliments module. Or do i need to add the config shown in compliments page.
      • T
        THeStigh
        Yes, you need to create them within config.js
        This is my config (replace ‘bla bla bla’ as you want):
        		module: "compliments",
        		position: "lower_third",
        			compliments: {
        				morning: [
        					"bla bla bla",
        					"bla bla bla"
        				afternoon: [
        					"bla bla bla",
        					"bla bla bla"
        				evening: [
        					"bla bla bla",
        					"bla bla bla"
        			updateInterval: 30000,
        			remoteFile: null,
        			fadeSpeed: 4000,
        			morningStartTime: 3,
        			morningEndTime: 12,
        			afternoonStartTime: 12,
        			afternoonEndTime: 17
        Please mark answer as correct and topic as Solved (if this solved your issue) :)
        D 1 Reply Last reply Reply Quote 2
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @dgregory19
          @dgregory19
          Or, use a remote file (as per the compliments readme) so as not to encumber the config.js file with a lengthy entry.
          • cowboysdudeC
            OR just use another module…
            https://github.com/cowboysdude/MMM-NiceThings
              dgregory19 @THeStigh
              @thestigh I’ll try this. It looks different then what is supplied by MM. I think i have the syntax wrong and haven’t learned yet how to do the coding. Thanks.
              • T
                THeStigh @dgregory19
                @dgregory19 As @Mykle1 stated, there is another way.
                Personally, I prefer to have all custom configurations in one single file config.js and all custom css in the custom.css, by this I can add/remove/replicate configurations/modules installed from device to device. Makes it easy to backup :)
                Another tip;
                Above each module in config.js, you can add disabled: false / true, to temporarily make a module not load on MM. Like this:
                			disabled: false,
                			module: 'MMM-Remote-Control'
                If you need anymore help, please let me know.
                  dgregory19
                  Thanks everyone! Figured it out. Onto breaking something else…
                    CheapDad
                    My apologies for resurrecting a dead thread, but it seemed like keeping all similar questions to one thread might be useful to others.
                    I was happy with the default compliments, but wanted to customize them to the user. I copied the compliments entries from compliments.js and inserted them into my config.js. I don’t get any errors when I run config:check, but the compliments no longer appear on the screen. Here’s my code:
                    			config:  {
                    				compliments: {
                    					anytime: ["Hey there Emma!"],
                    					morning: ["Good morning, Emma!", "Enjoy your day!", "How was your sleep?"],
                    					afternoon: ["Hello, Emma!", "You look beautiful!", "Looking good today!"],
                    					evening: ["Wow, you look great!", "You look nice!", "Hi, Emma!"],
                    					"....-01-01": ["Happy new year!"]
                      sdetweil @CheapDad
                      @cheapdad u should have gotten an error in the window where u start MM…
                      I do copying your stuff
                      SyntaxError: Unexpected token '}'
                          at wrapSafe (internal/modules/cjs/loader.js:1060:16)
                          at Module._compile (internal/modules/cjs/loader.js:1108:27)
                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                          at Module.load (internal/modules/cjs/loader.js:992:32)
                          at Module._load (internal/modules/cjs/loader.js:885:14)
                          at Function.f._load (electron/js2c/asar_bundle.js:5:12738)
                          at loadApplicationPackage (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16)
                          at Object.<anonymous> (/home/sam/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9)
                          at Module._compile (internal/modules/cjs/loader.js:1152:30)
                      and npm config:check says
                      (base) sam@sams:~/MagicMirror$ npm run config:check
                      > magicmirror@2.15.0 config:check /home/sam/MagicMirror
                      > node js/check_config.js
                      [24.04.2021 15:25.20.258] [INFO]  Checking file...  /home/sam/MagicMirror/config/config.js
                      [24.04.2021 15:25.20.270] [ERROR] Your configuration file contains syntax errors :(
                      [24.04.2021 15:25.20.270] [ERROR] Line 56 column 7: Parsing error: Unexpected token {
                      shorter answer, u are missing a }
                        CheapDad @sdetweil
                        @sdetweil That’s the strange thing, I’m not getting any errors when I run npm run config:check.
                        Unfortunately, I had to rebuild my config.js since I installed a module, edited config.js and ended up with a blank screen that no commenting the config.js entries didn’t fix.
                        Here’s the new (old) compliments entries:
                        			config:  {
                        				compliments: {
                        And my npm run config:check:
                        pi@emmasmagicmirror:~/MagicMirror $ npm run config:check
                        > magicmirror@2.15.0 config:check /home/pi/MagicMirror
                        [24.04.2021 16:58.15.197] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                        [24.04.2021 16:58.15.352] [INFO]  Your configuration file doesn't contain syntax errors :)
                          sdetweil @CheapDad
                          @cheapdad
                          the thing is
                              module:"name",
                              position:"...",
                                  compliments: {
                                  }   //< ---- this brace is missing
                          get bitvise ssh client, then u can have a file manager view from windows
                          and use notepad++ to edit  and see the  brace, paren and bracket matching
                            CheapDad
                            Forgive me for pursuing this, but I see an opportunity to really learn here. When I look at my code, I have closed all of my braces:
                            			config:  {  \\ open
                            				compliments: {  \\open
                            		}   \\close
                            	}, \\close
                            			module: "weather",
                            If I add another closing brace, won’t I have an error because there is no opening brace?
                            On the suggestion for bitvise ssh, I’m working directly off the pi itself. I would love to run the entire MM configuration in a vm until it is right and then simply copy that over to the pi, but that’s a bit beyond my knowledge level.
                              sdetweil @CheapDad
                              @cheapdad u are missing the open brace for the module block in this last picture (see my layout above)
                              if you use bitvise then u dont have to edit ON the pi keyboard…
                              also gives u an ssh window to execute commands, again NOT on the pi keyboard
                              u can run raspian x86 in a vm on pc…
                                CheapDad
                                I think I figured it out and see where I needed a third closing brace. The weird thing is that Compliments seems to be the only module that doesn’t start with an opening brace, where all the others appear to. If I add an opening brace to it, I get an error. If I leave it out, it runs.
                                  sdetweil @CheapDad
                                  @cheapdad EVERY module MUST start with an opening brace…
                                  ignore any typos you find somewhere else…
                                  see my module diagram above
                                    CheapDad @sdetweil
                                    @sdetweil Got it.
                                      sdetweil @CheapDad
                                      @cheapdad I sent u a chat message
